Question about Compaq Presario 700 470024-192 Notebook
Sound Recording problem - ie. Mic sound is not accepting by C765TU model
My Compaq C765TU Presario Laptop is not able to record external sound (from mic/headphone) as the problem mentioned above. Please suggest what I have to do with this.
  • Sathees Kumar K.M. Oct 27, 2008
    Scholar:
  • 83 Answers
  1. click the sound icon in your task bar then click options then select recording settings. check the settings which will require you to show the settings of microphone. Recording settings should be tested through a sound manager. 2nd find the run command in your in the start up menu then type dxdiag to check your system information wether sound card was istalled. IF IT IS NSTALLED then check it thru sound detection input and out put aswell as the mic if its working.
Posted on Oct 22, 2008
  • Jonathan Agawin
    Jonathan Agawin Nov 09, 2008
    If it is inappropriate try to do this! If you have your movie maker you can test your mic if it can record narration for a certain movie clip. If it cant record still then your headset mcirophone should be replaced because its your problem. Got it................
C773: Audio -Internal Mic low sound, external not working
please check the settings from control panel->sounds and audio devices , there you can see voice-voice playback and voice recording.. , if not yet solved the problems, then you have to catch Service center
rd
siva
Jun 22, 2009 | Compaq Presario 700 470024-192 Notebook
Sound recording problem
Make sure the right sound drivers are installed, make sure your using a working microphone.
Also make sure your using the right program and that the microphone itself is plugged into the jack that is labeled with the picture of the microphone.
If you have done all of this and still can't get the mic to work then its a motherboard problem.
May 10, 2009 | HP Compaq Presario C700T
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Problem for my recording system
You say you can hear the otherside when online! Is it your microphone which isn't working rather than your speaker?
Go into your control panel- then sounds and audio devices-and click "voice" make sure that the mic is enabled and you can test the hardware here also. you could also use an external headphone and mic combo, your laptop should have ports for you to insert the jack plugs
Aug 28, 2008 | Compaq Presario 700 470024-192 Notebook
Inbuilt microphone is not working for C765TU win xp
hello
if you want see rest volume drivers klick on options, properties
Sound
Hello Jassimin:
First you have to isolate the problem, you need to check if it's a problem with your hardware of your computer or if it's a problem withn your software.
First try using Microsoft Sound Recorder (usually it's located at Start -> Accessories -> Multimedia -> sound recorder.
Try recording anything using that, If you can do it; then probably it will a problem with your software MSN, try re-isntalling it.
If you cannot record anything, of if you get a message that there's no recording device; then it's something related with the microphone or the driver for the mic....In case you need the driver, please let us know the model number of your laptop (usually it's a the bottom ....
good luck
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Compaq presario c772tu inbuilt mircophone not working
You may need to adjust the sound sttings for this device. Also, check to see if you have the drivers this device.
Jun 27, 2008 | Compaq Presario 700 470024-192 Notebook
Help me with the sound and mic. issue, i am using compaq persio v3000 ...please
I had the same problem with a compaq presario f700 with windows vista this solved my problem hope it helps you.
You need to download a codec called truespeech or tssoft32 link below hope this helps you.
Good luck
http://www.vistax64.com/sound-audio/125595-dsp-group-truespeech-audio-codec.html
Apr 07, 2008 | Computers & Internet
Internal MIC not working
If you are using xp, try going to the control panel, sound and audio devices, click on audio tab.
to check the mic settings, click on the volume tab under the sound recording sections. Make sure that the mic is selected and the volume turned up. It may be working only to record, not to hearback without recording...so you may have to actually be recording or talking to someone to know if its workings.
To check the sound, check to see if your audio device is selected under "sound playback" section...and make sure that all channels are unmuted and turned up. you may also have to check the volume control on the laptop (actual buttons on the pc) if there are any, and make sure that the volume is up and unmuted there also.
Hope this helps.
Mar 30, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 700 470024-192 Notebook Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
