I have a problem similar to Mr. Vaibhab's. The cassette holder will not close and load. It keeps on ejecting the tape. There is a message saying "condensation detected". I checked the official Canon site and they suggested to keep the tape-holder open for couple of hours to dry out the possible droplets inside the camcorder. I tried it but didn't work. Some people suggested to dry it out with hair dryers.......what do you think? Does anyone know how to repair this poor Elura 50 Baby?
I have sent my camcorder to Canon in Mississauga once but our great Canada Post somehow lost the camcorder initially and then after many many many days, after numerous complaints to Canada Post, they finally delivered it to Canon. So you can gues that I don't wanna send the Camcorder again to Canon either in Mississauaga or Montreal.
have not went near my camcorder for a year now it says i have codensation have left it open to dry out for 24 hours nothing happening please help e mail kcshaft@hotmail.com
-   Guest
Drying the unit with a hair dryer would be dangerous as you could very easily overheat something. If you have the unit open & in a dry environment at room tempreture for several hours it should dry out and work if moisture is really the problem. It sounds like you either have a defective moisture sensor or a problem with the circuit which detects the moisture. If that is the case you will probably have to have it serviced by a tech. If there are none in your area your only choice would be to send the unit to Canon. If you have to send it, insure it for the cost of replacement, in case it is lost or damaged. Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Aug 12, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dont start a the begenning of the tape, use another tape that has been watch for 2 minutes lenght! it works for me!! good luck
People, I got the same problem like 5 minutes ago, but I fixed it. You
have to REMOVE the battery while the camera is off, then wait 2 seconds
and take it back inside. It works.
But I have an Canon Xm1, so I don`t know if it works for all of you guys, but good luck!!
Hello sirs. I have a canon ELURA50 and I want to capture video from my premiere cs3 bur premiere is...
(More)
Hello sirs. I have a canon ELURA50 and I want to capture video from my premiere cs3 bur premiere is not regognise the ELURA50. I tried to found drivers on the web but nothing. The update drivers i found asking for the cdROM came with the camera and i lost it. Please Any ADVISE???
my canon elura 50 mini dv digital camcorder just wont turn on. ill plug in the power adapter,or use...
(More)
my canon elura 50 mini dv digital camcorder just wont turn on. ill plug in the power adapter,or use a fully charged battery and it wont turn on. what can i do???
