Error on Westinghouse mastermind 708 front loader washing machine
The washing machine is showing "de" as error and it blinks on the front panel until it is turned off, once turned on again it will be a few seconds and then the error blinks again.
Please assist
Thanks
Robert
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Posted on Feb 06, 2009
  • dmjohnston Dec 11, 2010
    SE error refers to a sensor error, remedies include checking all connections plugs:
    § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in
    the MOTOR.
    ƒ_’ reconnect or repair the contact in the connector
    The electric contact between the connectors
    (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is
    bad or unstable.
    ƒ_ Reconnect or repair the contact in the connector
    • The connector (6 pin, male, natural) in the Wire Harness is not
    connected to the connector (6 pin, female, natural) of PWB
    ASSY(Main) or the electric contact of connectors is bad/unstable.
    • The electric contact between the connectors ¡a6 pin, male in the Wire
    Harness and 6 pin female in the controller(Main)¡bis bad or unstable.
    • The Wire Harness between Hall Sensor in the MOTOR and PWB
    ASSY(Main) is cut(open circuited).
    ƒ_ Repair/replace the damaged WIRE HARNESS
    • The Hall Sensor is out of order/defective.
    ƒ_ Replace the Motor
    • The controller(Main) is out of order/defective.
    ƒ_ Replace the PWB ASSY(Main)
My washing machine won't turn on, when it finally did, it showed up error CL and won't let me program it
Posted on Jul 20, 2011
The "CL" means Child Lock has been activated and no programing can take place whatsoever, even if you unplug it and re-plug it. It is NOT an error. It is normal operation. Read the instructions on how to unlock/deactivate the Child Lock. On Westinghouse 708 it is done by pressing the buttons "Time Delay" and "Drip Dry" simultaneously for 3 seconds
Posted on Dec 14, 2014
I had same error on my machine now second time, first time was waste water pump jammed, second time was problem with front doors. Doors could not be locked as the catch was bit skewed.
Posted on Jul 22, 2011
I have a Westinghouse front loader 708 it starts to fill not much water goes in then it try's to wash and comes up with a Ce error
Consult the owner's manual--usually the Troubleshooting section. Or search internet for the Make + Model + the word "Ce"
Mar 05, 2016 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Jan 07, 2011 | Westinghouse Washing Machines
ERROR CODE CL for a Westinghouse front loader Model 708
Hi, cl means that the machine is over loaded, push stop clear to clear then try again with a lighter load....
Take care
Jun 15, 2010 | Siemens WE61021GB Front Load Washer
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Oct 23, 2009 | Westinghouse Washing Machines
Door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 13, 2009 | Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Jun 03, 2008 | Washing Machines
Washing Machines Logo
1,888 people viewed this question
Top Washing Machines Experts
