Question about Toastess TT-415P 4-Slice Toaster
The level of the toaster doesn't lock
Hi there, After I cleaned up the toaster yesterday, I can't toast my bread the next morning. I just peeked inside the slot & saw that the level bars were loosen on the far side of the handle. How should I fix it without taking apart the toaster? Please help me ASAP!
  • Anonymous Mar 30, 2014
    Right two slots won't heat up
    How do you take it apart without breaking it
  • 1,476 Answers
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Posted on Jul 19, 2006
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
I have a Phillips toaster. It has been working
it sounds like the magnetic coil which holds the lever down to the toast position has burned out. you probably can't get the part for repairing it as it would be too costly
Oct 04, 2009 | Kitchen Appliances - Others
My toaster does not lock in for toasting
Most small appliance are not worth fixing. If the mechanism that locks the bread handler is defective, I'd just buy a new toaster.
Aug 21, 2009 | Kitchen Appliances - Others
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
How can I clean the inside toaster rails
Hi rsands1,
The following link will help you maintain a clean and good toaster,
http://www.pnwb.com/Toaster%20Maintenance%20Parts%20.pdf
Thanks.
Nov 02, 2008 | Dualit CTS4E 4-Slice Toaster
Tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Feb 26, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Toastess TT-415P 4-Slice Toaster Logo
321 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
Marvin
Marvin
Vincent_G
Vincent_G
ray gallant
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
