Question about Lenovo ThinkPad T61 Notebook
Inactivasion of touchpad
I am using a mouse and want to inactivate the touchpad - it is irritating me.
    President:
  • 2,022 Answers
Download the toucpad software form internet acording to your laptop model.and install it.it has all the controller in that.
Posted on Oct 21, 2008
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
Azoniaadamantane chloride what is the antidote
Self-care
  • If blistering develops, cold moist compresses applied for 30 minutes, 3 times a day can offer relief.
  • Calamine lotion may relieve itching.[13]
  • Oral antihistamines such as diphenhydramine (Benadryl, Ben-Allergin) can relieve itching.[13]
  • Avoid scratching.[13]
  • Immediately after exposure to a known allergen or irritant, wash with soap and cool water to remove or inactivate most of the offending substance.
  • For mild cases that cover a relatively small area, hydrocortisone cream in nonprescription strength may be sufficient.
  • Weak acid solutions (lemon juice, vinegar) can be used to counteract the effects of dermatitis contracted by exposure to basic irritants.
  • A barrier cream, such as those containing zinc oxide (e.g., Desitin, etc.), may help protect the skin and retain moisture.
Oct 03, 2014 | Health & Beauty
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
While typing it will jump to wherever the pointer is so if Im not looking I'll be typing on a whole different line. So irritating how do I fix this?
If you are typing on a notebook computer that has a "touchpad", your fingers/thumb are contacting the touchpad, and that results in a "click" of the mouse to set the "focus" where the arrow is pointing.
Then, the characters you type are inserted at the new location.
Nov 09, 2009 | Dell Computers & Internet
Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Jun 11, 2009 | Acer Aspire 5610-4648 Notebook
My sony laptop touchpad not working properly
i have two solutions for you. the touch pad can be disabled on the motherboard so plz hold-down the fn key and press the function key that has the sign of a hand pointing something and the second is that ur drivers that enables thae touch pad to work has been courrupted so plz try reinstalling for the touchpad or try repairing ur operating system.
Apr 07, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Laptop
are U sure therees no Handphone or mangentic things near the laptop? did u use usb mouse? optical mouse?
Aug 26, 2008 | Acer Aspire 5315 Notebook
Mouse/touchpad issues
Try to connect a external mouse.
If it does work ok with the external mouse . It means that their is a problem the touchpad.
Who can take it to a service center for repair or you can use the external mouse.
Thank you
Thewho1
Jun 29, 2008 | Computers & Internet
Lenovo ThinkPad T61 Notebook Logo
126 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
