Question about Tao XM2go Satellite Radio Receiver
High Pitched whine when using line out with car power adapter
When I use the XM2GO line out into my car stereo line in, it works fine as long as I run it off of the XM2GO internal battery. If I connect the car power adapter, I get a high pitched noise at a level that competes with the level of the audio. It doesn't make any difference if the car engine is on or off ... same problem either way. I even get whining noises with the XM2GO turned off as long as the car power connector is plugged in. I didn't have any problem with the home kit using the external power adapter and the line out to amplified speakers, but using the car power adapter seems produces the high pitched noise which renders usage unacceptable. Any thoughts ?
  • philbert396 Dec 09, 2007
    I have noticed the same problem with my XM2GO power car adapter. This happens with the ignition turned completely off. The problem has to be in the car power adapter. I am going to take it apart and add a capacitor (filter) to the output and see what happens. Looks like the unit is glued together, of course.
  • latture Mar 30, 2008
    i have the same issue. the car adapter works perfectly, except if the power adapter is on, then i get that high pitched whine. pioneer tech support told me to take it back. i did, and the replacement car kit has the same problem. i then went to radio shack and bought two ferrite coils and attached one to the line out cord and the other to the power cable. that didn't help either. also noticed the issue with the car off and on. also, my car is a toyota prius (hybrid) which i think does not have an alternator.
  • 215 Answers
I was ready to mention the car's alternator but you say the noise is there if the ignition is on or off. What type voltage adapter are you using? It sounds as if it's the culprit. If it's an inverter I could understand the noise being generated. Have you tried earthing ALL the components involved? Earthing problems can cause some mighty weird things to happen.\ Are you sure nothing else in the car is switched on? eg. another radio or something with an inbuilt oscillator. Try running the power for the adapter straight from the battery and put a noise filter in line. Are you turning the engine off but leaving the ignition switched on? Doing this can cause a noise from the fuel pump. Oh and make sure the antenna is correctly earthed. Apart from that, I'm stumped BMW
Posted on Jul 18, 2006
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
I have a magnavox 37mf331d/37 that has developed a high pitched whine.the longer the tv is on the louder the whine.the tv is 5-6 yrs old
It's likely a capacitor associated with the power supply having gone bad.
It's obviously beyond your expertise to repair it yourself.
Find a trustworthy repair shop and take it there.
Sep 05, 2012 | Televison & Video
High pitched whine
The most common cause would be a defective power steering pump.
Aug 29, 2012 | Cars & Trucks
Continued battery drain and high pitched noise when car started
Maybe the alternator is bad. A high pitched whine could mean that the alternator is not working properly.
One can test, by removing the belt to the alternator and running the engine and seeing if the whine goes away.
Jan 16, 2011 | 2000 Toyota ECHO
High pitched noise coming from speakers after installing stereo
you may need to use a power line noise reducer or if useing amps a rca line noise reducer
May 10, 2010 | Boss BV9560 Car Video Player
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Engine noise only when playing ipod through line in adapter
Did it always make noise or did it start recently? You need a ground loop isolator. That usually clears up the engine noise.
Feb 28, 2008 | JVC Sirius KD-LH300 CD Player
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Tao XM2go Satellite Radio Receiver Logo
396 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
