Question about Jensen A600HLX Car Audio Amplifier
Jensen A600HLX ok well i just read ur solution about my Jensen A600HLX and i pretty much understand alot of it, its just i dont kno wat these thingys look like, and is this problem something i can fix without bringing it into a technician? thanks - Tom
    President:
  • 3,130 Answers
These solid state amps have no user serviceable parts inside them as everything is soldered into place and your gonna need to know how to use a multimeter to trouble shoot the parts inside the amp on the printed circuit board. Sorry But without the proper training and the right tools you could cause more damage to the amp if you dont know what your doing. You cannot just open the unit and see whats bad. You must test each suspected bad part and replace it as needed. You should take the amp in to have a pro look at it, as there is no easy fix on these unless its an external fuse, and a fuse will very rarely blow all by itself. Good Luck
Posted on Jul 17, 2006
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
I have 2 12inc clarion subs 600w wat amp would u
what subs? do you have a part # or do you know are they single post or "dual" posts?
Jun 14, 2009 | Jensen A600HLX Car Audio Amplifier
Jensen vm9311ts dont kno where pink wire goes or anything
go to www.google.com then type JENSEN CODE and get the first option .
Feb 27, 2009 | Audiovox VM9311TS
I got it smoking
it would be cheaper and smarter to buy a new one
Nov 25, 2008 | Jensen A600HLX Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Need Help
input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Jensen A600HLX
check pwm ic 494 or other
Dec 16, 2006 | Jensen A600HLX Car Audio Amplifier
My amp went into protect
See my solution for: http://www.fixya.com/problems-solutions/t115301,p424435/Eclipse-Car-Amplifiers.aspx And they shouldn't need a schematic unless they can't read the part numbers of the fried components.
Jun 08, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX Car Audio Amplifier Logo
141 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
