Your philips volume control problem
I have exactly the same problem as you (except I have the 170b model). I took it apart and it has more than 7 pins. I'd like to try the same approach, but i'm a software kind of a person, not a hardware one, so i'm a bit nervous. How easy is it to bend the pins back once you've find the right one? Won't they snap? Did you get a replacement board for the buttons in the end?
Cheers,
Poldie
5 Suggested Answers
  • 7 Answers
SOURCE: Blank screeen
Been there, done that. The power LED cycling indicates that the switchmode PSU is shutting down and trying to restart over. Standard symptom, let me guess the bulging cap is on the top row. Replace it with a same value/voltage (1000uF/10V from memory) low ESR 105C type and you'll be back in business.
Posted on May 07, 2009
  • 9 Answers
SOURCE: I have a left-right blur on my Philips 170B
if u'r eng. change the crt base in video board or u'can set u'r defocusing prob by EHT focusing section
Posted on Dec 12, 2009
budmrtn
  • 11361 Answers
SOURCE: Right arrow button isn't sensing my touch
It can be the switch is broken or the ribbon cable may have come lose during shipping, the problem is the way the caseis put together with plastic snap-clips which can easily be broken during diassembly of the case, you may also leave some scratch marks during opening also, the seller may not like that and may not honor any warranty.
Posted on Apr 01, 2010
nkrcs
  • 94 Answers
SOURCE: My philips170b lcd can't produce sound.It
The problem could be that your motherboard requires "active Speakers" IE: speakers with their own amplifier. A lot of the newer Motherboards are now like this to cover the use of 5.1 surround sound speaker systems. If you have a set of Active speakers or can borrow a set off of a friend it should show you if this is the case or not
Posted on Jul 24, 2010
Bought a genuine remote off eBay for a Harman Kardon HK 3250. Drives everything fine except the volume control. Would it be faulty or doesn't it work due to a wind volume control?
Turning, or winding, volume controls can still be adjusted with the original remote control. You should check to see if it is the exact remote that originally came with your model. Different model remotes might control some functions, but not others. The remote is most likely not broken, just the wrong one.
Apr 28, 2017 | The Audio Players & Recorders
Ihave a philips dvd/tv remote, but i can't get it to operate my magnavox tv except on/off and volume, can you help?
There are a number of different codes for each TV, pick the one that works best for example these are for magnavox, but since I don't know the model no of your remote they might not be correct for yours! 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
Jul 21, 2014 | Philips Televison & Video
I have a Philips 170B7 monitor. The volume adjustment bar always appears in my screen. It's very disturbing. The volume also ups and downs automatically. How can i remove this problem? [ I have cleaned the...
I had this exact problem with a Philips 170B. I thought there was dust/bugs in there and tried blowing them out, to no avail. Eventually, I decided I had nothing to lose - I dug in and see what was going on.
  1. There are three screws:
    • one each side, on the back toward the bottom
    • you also have to take off the stand - it has four bolts, accessible behind a plastic cowl - just pull the cowling off.
    • now you can get to the third screw - it's behind the stand. I didn't see it at first :'
  2. Pull up the two tabs on the bottom of the display, and ease your way all the way around the whole bezel with a spatula or something. Take your time.
  3. You can now get to the circuit board with the buttons on it. I unplugged the leads, the two screws, and eased it up off the two little pegs that locate it under the bezel.
  4. The volume buttons are labeled "left' and "right". I levered them little fellas up and yanked them off with me pliers :)
  5. While this worked for me, be prepared to DESTROY YOUR MONITOR - I certainly was. However, I am delighted that I no longer have to go out and replace it with 24" of full HD beauty :/
http://imgur.com/hVg1r.jpg
http://imgur.com/RxnNM.jpg
http://imgur.com/yJOHP.jpg
Aug 14, 2010 | Philips Business 170B 17" Flat Panel LCD...
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Bose LS5 max volume!
you better replaced the volume control it is depected already with identical ratings so it works normal again.. Hope it may helps;;
Jun 08, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Volume Control Bar does not go away
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
ROD
Feb 09, 2009 | Philips Business 170B 17" Flat Panel LCD...
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
No buttons work...not even the volume and others along side
I had the EXACT same problem this morning. After leaving the cingular store where the guy just wanted to sell me a new phone, I went home and took the phone apart - just took off the battery cover, battery, sim card and the rest of the back cover, reattached cover, put everything back together and everything works fine now! Try it - good luck! You need a T5 torx bit to remove the two screws holding on the back cover.
Aug 31, 2007 | Motorola Mobility RAZR V3
Wont work when i turn volume up?
clean the volume control it could be dirty
Apr 03, 2007 | Philips FWC577 CD Shelf System
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
