Question about Car Audio & Video
No sounds through sub and rear speakers
I have removed the battery but when ive connected it only the 4 door speakers go but my sub and back speakers dont work these power to the amps all wiring hasnt been touched before this my sounds was pumping can you help please
    Problem Solver:
  • 6 Answers
Your radio probably has a sub on and off function on it that was reset when it lost power. Go into your setup menu to turn it on.
Posted on Oct 22, 2008
The left rear door window fell off the track. How do I remove the door panel to access it.
This is the complete procedure you stop when you see the problem.
1. REMOVE REAR DOOR INSIDE HANDLE BEZEL
(a) Remove the screw.
(b) Using a screwdriver with its tip taped, disengage the 2 claws A.
(c) Pull out the the rear door inside handle bezel in the direction indicated by the arrow, disengage the claw B, and remove the rear door inside handle bezel.
2. REMOVE DOOR PULL HANDLE
(a) Using a screwdriver wrapped with the protective tape, disengage the 2 clips and remove the door pull handle.
3. REMOVE REAR DOOR TRIM BOARD SUB-ASSEMBLY
(b) Disengage the 7 clips.
(c) Disconnect the connector and pull up on the rear door trim board sub-assembly to remove it.
4. REMOVE REAR DOOR INSIDE HANDLE SUB-ASSEMBLY
(a) Remove the bolt.
(b) Disengage the 2 claws and separate the rear door inside handle sub-assembly.
(c) Disconnect the 2 cables and remove the rear door inside handle sub-assembly.
5. REMOVE REAR SPEAKER
6. REMOVE REAR DOOR SERVICE HOLE COVER
(a) Disconnect each connector and remove the rear door service hole cover.
HINT:
Remove the remaining tape on the door side.
7. REMOVE REAR DOOR GLASS RUN
(a) Connect the window regulator switch assembly.
(b) Fully lower the door glass.
(c) Remove the rear door glass run.
8. REMOVE REAR DOOR WINDOW DIVISION BAR SUB-ASSEMBLY
(a) Remove the 2 bolts, the screw and rear door window division bar sub-assembly.
9. REMOVE REAR DOOR QUARTER WINDOW GLASS
(a) Pull out the direction indicated by the arrow, remove the rear door quarter window glass and rear door quarter window weatherstrip as a unit.
10. REMOVE REAR DOOR QUARTER WINDOW WEATHERSTRIP
11. REMOVE REAR DOOR GLASS SUB-ASSEMBLY
(a) Remove the rear door glass sub-assembly as shown in the illustration.
(b) Disconnect the window regulator switch assembly.
12. REMOVE REAR DOOR WINDOW REGULATOR SUB-ASSEMBLY
(a) Disconnect the connector.
(b) Loosen the temporary bolt.
NOTICE:
If the temporary bolt is removed, the rear door window regulator may fall and become deformed.
(c) Remove the 3 bolts and the rear door window regulator sub-assembly and the power window regulator motor assembly rear as a unit.
(d) Remove the temporary bolt from the regulator.
13. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY REAR
(a) Using a "torx" driver (T25), remove the 3 screws and power window regulator motor assembly rear.
14. REMOVE REAR DOOR LOCK ASSEMBLY
(b) Remove the bolt.
(c) Using a "torx" socket wrench (T30), remove the 3 screws.
(d) Slide the rear door lock assembly downward, pull out the link from the outside handle frame, and remove the rear door lock assembly and cables as a unit.
(e) Remove the door wire harness packing.
(a) Using a "torx" socket wrench (T30), loosen the screw.
(b) Disengage the 2 claws and remove the rear door outside handle cover.
(a) Disengage the 2 claws and remove the rear door outside handle pad rear.
Jan 03, 2011 | 2006 Toyota Highlander
Hello. I need help installing an Eclipse sound system in my Dodge Ram 1500 Quad cab. I went from a Kenwood HU with db Drive 6.5's and 5x7's to the Eclipse CD3200 HU and noticed an immediate improvement...
So you wanna run the subs off of the rear pre amp output rather than just the sub out correct? just get a splitter and run both the rear speakers and sub off of rear channel and front off of front channel. or run all four off of front and subs off rear output. this should give you the sound you want
Nov 04, 2010 | Car Audio & Video
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
No Sound from speakers BUT sub is working fine?
try to unplug and then plug again all the speaker's connections...make sure you do the right connections...or get a AA or AAA size battery,put the + side of battery to the + of speaker(alone/unplug),and momentarily touch the negative(-) side of battery to the negative(-) of your speaker,,you must hear a click from your speaker...if there's no click,you have a defective speaker..
Feb 08, 2009 | Altec Lansing VS2421 Main / Stereo Speaker
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Jul 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Side Speakers
have you checked the settings on the default windows settings to surround? just a thought!
Feb 19, 2008 | Creative Labs Inspire T7900 Computer...
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
