Question about Gateway LCD26TV 26 in. Television
Gateway 26" LCD Power Supply
I have a Gateway 26" LCD TV and one half of the power supply is fried. It's the half that powers the LCD panel. Does anyone know where I could locate one of these?
    Problem Solver:
  • 10 Answers
There is a silver lining....
Unless you physically see burned components on the power supply main board, it
is not fried. If you examine the board on the back side ( solder joint side) you will notice that there is a devider that is clearly marked between the Primary and secondary sides of the board. There will also be a large transformer accross this area.
All switch mode power supplies have optical couplers which cosist of a light emmiting diode usually infared and a photo transistor. These are for protecting the secondary side of the board or the expensive side. A typical switchmode power supply for an LCD tv will have at least three of these. They are roughly 1/4 inch long and 2/8 inch wide
and are black with four leads. They will be directly accross the marked portion of the board that seperates the primary or high voltage side of the board from the secondary.
These opticle couplers or switches cost an average of $ 7.00 a piece and are available
from any electronics supplier such as NTE.
I hope this helps. Remember it can all be repaired. Its a matter of if its economically
worth your time.
Posted on Feb 03, 2008
  • 1,476 Answers
Gateway's are made by Delta Electronics. In the past I have tried to get service manuals and parts from them but they will not sell to anyone other than authorized agents. If you have identified the bad components and they are not proprietary or special units you may be able to repair the power supply. With the exception of the transformers the other parts should be off the shelf and available. The question may be whether you can identify them due to burning etc. A bigger question may be why did it fry in the first place? Is there a short somewhere else? Something caused the overload. If it was the LCD panel you have bigger problems. Good Luck.
Posted on Jul 18, 2006
What keeps killing my power supply in my samsung lcd tv.
There is a short or ground some where that is frying your supply board
Dec 09, 2017 | Samsung Televison & Video
Why doesn't it turn on?
Hi check the power supply of the tv first . Check the bellow added video to understand how check the power supply a lcd tv .
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 01, 2015 | Sharp LC26SB28UT 26 in LCD TV
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Everytime I turn the RCA L26WD12 26 in. LCD TV on it powers off and on a number of times before it finally stays on. Waited through the off and on cycle 26 times once.
You have problem with your power supply. A blown up capacitor need to replace. somewhere in the output of the power supply.
Aug 13, 2011 | RCA L26WD12 26 in. LCD TV
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
Tv won't power up after a storm
Now the tv have a flashing LED power light indication on the LCD panel or dead no LED light at all?Yes,than the power supply board it dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 20, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Power supply replacement for a lcd Toshiba install video
Try website like You Tube,type in LCD tv power supply replacement,should have a tutoring video by somebody doing it,the replacement.
Jun 23, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
No power. nothing
U can tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to fix it ur self.Buy it ur self, to do it ur self.The power supply board should cost $120 to $140 plus shipping.The shop should cost $300 to $400 for power supply board part and labors.
Mar 02, 2010 | LG 26LX2R 26 in. HD-Ready LCD TV
Same problem.
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
Sep 17, 2009 | Memorex MLTD2622 26 in. LCD TV
Tv no power ,dead
PS- I fixed this model this morning.
Aug 12, 2009 | Memorex MLTD2622 26 in. LCD TV
Gateway LCD26TV 26 in. Television Logo
571 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
