Question about Candy Dryers
My daughter has a candy condenser cc21 7 dryer but the unit does not get hot just blows out cold hair ?
  • 67 Answers
The heating element is probably bad. most dryers come apart from the front, starting with 2 screws on the bottom of the front. the heating element is usually in the back and kind of looks like the inside of a toaster, but bigger. they are not hard to replace, just make sure you turn the power off first.
Posted on Oct 21, 2008
I have Candy condenser dryer & it is not getting hot what do I need to change.
I would start with checking your thermostats in which you should have 2 or 3
Jan 20, 2015 | Candy Dryers
It blows air but it is cold it does not get hot had thermail limi
Depending on the type and make or model of dryer check drum turns,filters are not blocked or condenser is not blocked.then if all ok it could be the safety thermostats or the heating element.
Hope this helps.
May 10, 2010 | Dryers
Not blowing cold air, do u recharge this unit?
only after you find a leak. first u have to make sure if the compressor is running at all. condenser side spinning. if compressor is not working it will blow hot air if the condenser is dirty or blocked but then u would get a minute or two of cold air then hot. you have to determine its empty or what else might be the cause before you start dumping in freon.
May 25, 2009 | Samsung Heating & Cooling
Safeguard mode
Eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC GR-D73AG Mini DV Digital Camcorder
JVC VIDEO CAMERA CONDENSATION PROBLEM
Please eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC Video Cameras
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
Dryers Logo
137 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
