Question about Microsoft Office Professional 2007 Full Version for PC
Email is greyed out on office 2007
I click "send" but email is greyed out. So I send it as an attachment which the receiver says won't open (she thinks it may be something to do with an x following doc). Appreciate advice.
  • 903 Answers
The receiver cannot open the document because they do not have office 2007. There is a compatibility pack that she can download from microsoft.com that will allow her to open all documents from office 2007. It's quick and easy to install and will stop her from having any other problems in the future if other people send documents from office 2007. i hope this helps
Posted on Oct 21, 2008
What do I have to do to open up my email attachments??
In most cases you can click on the attachment name. However you will need to ensure you have a program installed capable of opening the attachment. For example if someone sends you a file with extension of .pdf you will need adobe reader. If someone sends you a .xls you will need microsoft office.
These programs do not usually come pre-installed on your computer.
You can get adobe reader from http://www.adobe.com
And microsoft office is available at most computer stores.
If you receive an error that the attachment has been removed or blocked it may be a format the email provider does not allow.
Please provide more details or ask further questions if needed.
Nov 21, 2014 | Computers & Internet
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
Aug 07, 2012 | Microsoft Exchange 5.5 Outlook Web Access...
The server rejected my email and won,t send it
hmm
check password
make sure attachment is not too large
shut down email app and restart and try again
May 23, 2012 | Microsoft Office Outlook 2007: Windows
Send as attachment email held in 2007 Outlook Outbox
It sounds like the attachment may be to large for her to send via email. Email applications have a size limitation on how large of an attachment you can send. I would try to take the file break it down into smaller sizes and send those as attachments to see if they go through. For aneasy test before going through the trouble of creating smaller files make a word document. Name it test write this is a test document on the document and save it so it has some content in it and see if she can send it. If she can its probably the attachment is too large to be sent and you need to send it in smaller file sizes.
Cheers mate!
J the Guru
Jul 18, 2017 | Microsoft Office 2007 Standard Full Ver...
How to send emails on windows office 2007 and how to send emails on office word 2007
First, you need to configure your email ID in Outlook to send an emails using Office 2007 and then draft an email in word 2007 and navigate email (Send a copy of documet in an email message as an attachment) options from file menu send option
Dec 10, 2009 | Microsoft Office Home and Student 2007 for...
When an emailing an attachment for an example a resume. They other user can not open the attachment i had sent. How can I get this opened?
The possible causes are two:
1. You are sending out a format which the recipient doesn't support (e.g. OpenOffice). To solve this, install utilities such as PDFPrinter, or export the document as PDF. This is a format which almost anyone can read, even if they can't edit it. Otherwise go for Microsoft Office or, if you use OpenOffice, set it to save as "Microsoft Word Document".
2. The recipient has some kind of security in his/her computer which disables opening of all kinds of attachments, possibly excepting only some "deemed safe" ones. There's not much you can do here. Sending documents in Microsoft Office formats sometimes improves chances they'll be deemed secure.
Oct 31, 2009 | Computers & Internet
Win Mail Attachment Problem
Try this with your email and then send an attachment.
  1. On the Tools menu, click Options, and then click Mail Format.
  2. In Compose in this message format, click to select Plain Text, and then click OK.
Feb 02, 2009 | Microsoft Office Professional 2007 Full...
Sending attachments in Outlook 2003
Have you tried the repair option in Outlook? From the help menu, you can choose Detech and Repair. Also, you can choose to repair all of Microsoft Office from the Control Panel, Add and Remove Programs, find Microsoft Office, and click change. Then You can choose to repair.
Jan 26, 2009 | Microsoft Office Professional 2007 Full...
Windows email
IS YOUR EXCEL 2003 OR 2007. I WILL TRY MS OFFICE 2007
BECAUSE VISTA SOMETIMES HAVE PROBLEM READING SOME PROGRAM IN MS OFFICE IN 2003. EVEN WORD 2003 SOMETIMES HAVE PROBLEM IN VISTA. DEPAND ON THE COPY YOU INSTALL. I HAD PROBLEM WITH IT SO MANY TIMES
GOOD LUCK
Jul 13, 2008 | Toshiba Satellite A105 Notebook
Microsoft Office Professional 2007 Full Version for PC Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
