Question about Acer Aspire 4520-5582 Notebook
Recovery problem When i formatted,the hidden recovery partition was deletd,is there any way to make recovery CD.Is there any way to make recovery CD for window vista home basic using window vista ultimate.
    President:
  • Acer Master
  • 2,022 Answers
Chek ur bios setting may be if there is recovery key just use that othewise download form the net.
Posted on Oct 21, 2008
Smart recovery problem on every boot
Since you used a program to resize the partitions it probably corrupted the file and\or made it unusable. I would recommend doing an entire system format of both partitions then backing up onto the separate hidden partition again and it should work.
May 12, 2013 | LG X120 Netbook
Lg smart recovery
Resizing the partitions has affected the partition size of the hidden recovery partition. This is why the recovery does not work.
You need to get a Recovery CD for your model LG laptop from the LG WEB site so you can restore your laptop.
You maybe able to download the recovery CD from this site : -
www.notebook-driver.com/lg/lg-notebook-lm40lm50-driver/
May 12, 2013 | Computers & Internet
Hi All\r\n\r\nReq. to all please provide me confirmation regarding "one key recovery" firstly i must tell you i am using netbook lenovo "s10 series windows 7, now if i format hard disk(C:)...
Hi Nishant,
I saw you post about the One Key Recovery on your S10-3 system and I would like to Help.
You mentioned that you have an S10-3 system and that it has Windows7 on it and that you want to install Windows XP on it.
I guess that can be possible as long as you do not delete / format the partition where the One Key Recovery is located your One Key Recovery can still be utilized once you may need to set the system back to factory defaults, the Partition where the One Key Recovery will sometimes be name Lenovo Recovery Partition and cannot be seen in windows since it is a hidden partition only seen when doing an installation of windows using a retail Windows Installation cd.
Just to add about the OKR or One Key Recovery once you downgrade to XP and you use the One Key Recovery it will restore the system back to factory defaults then windows7 will be the operating system again on your s10-3
Nov 12, 2010 | Lenovo IdeaPad S10-3 Netbook
I have a packard bell iMedia Z869 and wish to restore it to factory fresh. It has a hidden partition (I assume it is the recovery partition). How do I access the recovery option?
Get or create a windows boot disk
If you dont have one, write back to me so I can help you with creating one.
Once you get your boot disk in your cd / dvd drive, have the pc boot into this cd
The cd will boot and ask you to pick one out of 3 choices:
Pick the first one saying "with cd support" in the sentence
The cd will now boot in dos and end with it saying that all it's tools are on a certain drive letter
Note the letter it says and access this letter by typing :
d:\ z:
The above is an example ( you must note where the tools are under the drive letter that the software says)
Once you access that drive letter, type this:
z:\fdisk
This program fdisk will open up and show you more choices to choose from
This program is used for controling all the partitions in your hard drive(s)
You will now look at the list of choices and sellect "View partitions"
See if you can now view the hidden partition that may contain the recovery partition and note the drive letter and type of partition (dos extention or whatever )
go back to the first set of choices again and now choose #2. Set active partition.
This will take you to a page that shows all the partitions (hidden and unhidden) and now you will click or select on the hidden partition to make it primary
after that exit the fdisk program and the unit will now reboot
If the unit's software does not work, it's only because the hidden file may have no recovery software or worse: it will demand for the original recovery cds to continue.
Please write me back and let me know how it goes.
Jun 14, 2010 | NEC Computers & Internet
How do i reset the m305-s4910 to factory setting
Recovery
  • How to recover a Toshiba notebook with the HDD recovery procedure
  • http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
From CD
  • http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
You may have a hidden partition on the harddrive - if so you can recovery from there - BUT - you should also be able to create some bootable recovery DVD or CDs from the hidden partition using the toshiba recover cd creator Two ways to get to the hidden partition on Toshiba
  • Press an hold the zero key and power on - this will enable the recovery menu
OR on later models
  • Tap F8 as it boots and then use repair computer - from menu
  • How to recover a Toshiba notebook with the HDD recovery procedure http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
if not you can order replacement recovery cds
  • https://backupmedia.toshiba.eu/landing.aspx
Apr 10, 2010 | Toshiba Satellite M305-S4826 Laptop
How to recovery without cd sony vaio
When you turn it on, if you are given the choice of what to boot[press F8? key when booting], pick the recovery console, and recover from the hidden partition on the hard disk. Most allow you to use the hidden recovery partition to make a DVD for backup. I would do that, too.
tom
Dec 21, 2009 | Sony VAIO Notebook
How can I do a complete system restore without a disk? Take my computer back to how it was when we first purchased.
If your system is a HP Pavilion then at startup or boot you can press F8 or F10 Im not sure about the exact keys, but hp stores a recovery of the OS on a partition which is usually hidden and does not have access from within the OS.
So try using function key that works for your system, the recovery will start automatically.
but remember this deletes all the data on the primary partition ie the OS partition.
If this thing does not work check if there is a recovery partition that needs to be burnt on the CD/DVD.
Else you need a OS disc and format the PC and reinstall the OS
Jun 23, 2009 | HP Pavilion m7640n PC Desktop
I formated completelly hdd (acer 7720g) i want to to recreate pqservise in order to have d2d recovery(recovery management).i have the dvd recovery of factory settings but the dvds didnt manage to create...
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
May 23, 2009 | Acer Aspire 7720-6155 Notebook PC
Acer aspire 5600
you cannot, you said you have formated it, theres no going back, you will have to do a system backup using system tools in accesories
Aug 31, 2008 | Acer Aspire 5610-4648 Notebook
Reformating the hard drive
high level format should appear as an option from recovery cd..
Apr 19, 2008 | Toshiba Satellite A45-S150 Notebook
Acer Aspire 4520-5582 Notebook Logo
302 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
