Question about HP DeskJet 3550 InkJet Printer
Printer is not loading paper
My HP Deskjet 3550 printer is not loading paper when I try the Print Test Page or other print commands from Windows.
How do I issue a Self Test from the Printer directly other than from Windows - since I don't see any response from the printer when I press and release the ON/OFF button for some time - commonly done on HP Printers.
I only see the light blink for some time and then either be ON or OFF
Pls let me know what could be the issue before I send it to the service center
Regards
Sancho
    Sergeant:
    Champion:
  • 274 Answers
The blinking lights are probably error codes. By the sequence, you can tell where the problem is. Also, you should be able to hold down certain buttons, when you power on the printer, to get tests.
Check the HP Support Website for more info...
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodTypeId=18972&prodSeriesId=305946
Posted on Nov 18, 2008
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
My Hp 3550 colourInk Deskjet is confronting an
remove data cable put it into another then try
Jun 26, 2010 | HP DeskJet 3550 InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Printer does not function
Friend,
In most cases this is caused by a faulty driver or a broken printer cable. Please try to print an internal test page to ensure the printer itself is working properly, then replace the cable and ensure the driver is pointing to the right port if the internal test page prints properly. Also you could try to print the driver's test page (driver properties > Print test page > answer "Yes" anyway, since answering "No" only produces a bunch of suggestions that won't help you solve the problem!). If this works, the problem resides somewhere between the driver and the application(s) you're trying to print from.
//Al
Jan 22, 2009 | HP DeskJet 3550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
Test page from hp 3550 with out attach computer
power on your printer.
While press & hold power button open & close the top cover for 5 times and release the power button.
Sep 09, 2008 | HP DeskJet 3550 InkJet Printer
Printer hp D1460
Please provide more details
Does the unti power on correctly ?
Can you see lights and the power up self test ?
What happens when you try a self test ?
Do you hear paper trying to be fed into the machine ?
are there any error messages ?
Etc..
Feb 09, 2008 | HP DeskJet 3550 InkJet Printer
HP DeskJet 3550 InkJet Printer Logo
188 people viewed this question
Ben Johnson
