A PDF document set in Gill Sans is reverting to another font when printed off. Any ideas why this might be?
  • 507 Answers
You need to setup default font in your printer, works with all generic printers. for more specific solution, kindly provide brand and model of printer and what is the software used for pdf printing.
Posted on Oct 21, 2008
How do i enlarge font size
If the document is a word document you can chain the font size and type of font from the drop down menu showing the font and size of font.
If the document to print is a pdf file you cannot change the font size. All you can do is to increase the size of the dcumrnt by zooming the document and then print as is seen on the screen by choosing option and print as on screen.
Jan 10, 2018 | Office Equipment & Supplies
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Good day I am seeking for an assistance I need to change the status of an Epson lx350 printer on standard mode to be on HSD/Draft/Roman or Sans mode
The printer settings for the document are set in the document, not the printer. When the document is formatted the print style (font) is set and in the printer properties you should set for draft or standard mode
Sep 01, 2017 | Epson Office Equipment & Supplies
Misprinting with at least 2 fonts
Not sure yet whether it will be the solution, but I am tole it may because my MAC OX is behind, and I need to update both that and the software.
Jul 17, 2008 | Ricoh Aficio CL7000 Laser Printer
Tip
Radio Interference affecting the UPS
Erratic operation up to and including load loss due to radio or camera flash operation. Do not operate or let customers operate a radio or a camera flash near the critical power systems, especially if the doors are open. Various manufacturers have recommend not to use these devices near the UPS or other Critical Power Systems.
1. Depending on the physical layout and components used on the control boards, the controls may be affected by an Radio Frequency (RF) signal of relatively low strength at the right (wrong to the control circuits) frequency from a hand held radio.
2. Microprocessor circuits which often have a crystal for clock frequency, may modulate the signal in with the clock frequency and cause the CPU to lock up due to a missed or garbled instruction.
3. Analog circuits with high gains, high impedances, and diodes, may demodulate the RF signal and cause the controls to malfunction.
4. So far, cellular phones have not been detected to cause a problem, but it is still a good idea not to get them too close to the control circuits when in use.
NOTE: Units built for certain military applications must meet RF interference
susceptibility specifications. They have special shielding installed, but
even they may not meet the susceptibility specifications with the doors
opened.
5. It has been witnessed for a UPS to blow inverter fuses when a strobe flash on a camera was charging and the UPS doors were open. The RF from the strobe oscillator caused an inverter bridge to misfire.
6. It has also been seen to knock down a microprocessor controlled UPS when the strobe flashed and caused an EPROM to misread even though the UV eraser window on the EPROM was covered with a label. light still penetrated enough to garble the instruction to the CPU and cause it to lock up.
on Oct 21, 2011 | Computers & Internet
jasbo
jasbo
