Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Replaced lamp and new wires, then changed back to old wires still nothing.
I replaced the lamp and it didnt work changed the wires back to old and still get the blinking lamp light and tv doesnt come on?
  • nnsuck Oct 30, 2008
    how do you reset the hours under the menu??
    Novelist:
    Scholar:
  • 149 Answers
Once you replaced the lamp did you reset the hours under the menu? If you do not do that some times the set believes it's in warning mode and prevents a potential implosion of the lamp which creates issues such as the set not turning on, staying on that long, or the lamp light still flashes.
Let me know how that works out for you.
Also, what "old wires" are you referring to?
Posted on Oct 28, 2008
My left side tail light doesn't work after changing the lamp. Jeep 2007 - Commander
it worked before the change out?
there are 3 things that are first. on advance electronics, cars. like this. 2007 is 1st year, of wild complexity.
  1. check fuses first. MIP fuse #8,9,10 (8 is left) check that?
  2. check action of park relay
  3. check for trailer wiring hacks (do you have factory hitch option?)
  4. and scan the PCM , do you see any park fail DTCs'
DTCs are system errors.
that is first.
next if not solved, we look in the FSM for that chapter, and the schematics, to see how its is structured. (varies by year, car)
FSM JEEP XK 2007 (book)
factory service manual.
left side rear tail (park) (tail is old name , car has many park lamps now , not just 1 or 2 tails like in the old days.
so it park and the relay of same name.
there are front parking lights too... do those all work>?
my guess, is you didnt check fuses first.
am i right?
fuse 8 is blown?
but that takes out front left park
and left side marker (park ) lamps too.
so did you look at all left park lights first>?
i bet not, if im wrong then you do have wiring errors.
or the new lamp from china is shorted inside, (common)
try one more lamp , like from GE or Philips.
Feb 24, 2015 | Jeep Cars & Trucks
Samsung DLP TV no picture or sound 2 weeks old lamp
Hello, DAvid43, what model is your Samsung DLP tv?
Jun 01, 2008 | Televison & Video
Im having trouble with my 92 toyota pickup (4 cyl). My truck turned off on me on the streets(about 3 months ago), and didnt want to turn back on. It would sound like it wanted to turn on, but never did. So...
if it starts then stalls, its the wiring that goes to your air flow meter, if theres nothing at all that happens check for spark, if there is no spart its most probably your coil.
Aug 07, 2013 | Cars & Trucks
Radio not working
there are 3 power sources to radio. if stock, if not stock more.
Radio power.
memory power
and dial lamp power. (dimmer)
why not use a voltmeter to find out why its dead.
even better the FSM shows the wires, the colors and the path.
making guessing go to zero.
when working electrics pull battery minus lug, like the FSM directs you.
and keys in pocket. causing load dumps can cause very expensive
electronics to fail. even the EFI, PCM.
Jun 04, 2013 | Honda Civic Cars & Trucks
I have an electrical issue. The igniter effected the number one cylinder, quit firing, tach quit working. I replaced the igniter and it not only didnt work, it didnt even deliver fire to any of the...
Its not uncommon to have a defective new part ,Try another unit .IF the problem sill exists then you have an electrical short or bad connection somewhere .
Mar 12, 2010 | 2001 Triumph Adventurer
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Rough idle no power when given gas
check spark plug connections,if you didnt replace the cap and rotor ,they will fail quickly,because new wires and plugs are going to demand more current,old cap and rotor just cant handle,is that the mass air flow sensor that you replaced?very delicate part,must be clean,and mounted securely,double check part no. make sure they gave you the right one,if you put in a used one ,all i can say is that you get what you pay for.check fuel pressure,its possible that the fuel pump is starting to fail,and the tune up has nothing to do with the problem(consider this option only if nothing else works)
Sep 22, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Red light blinking 3 times on Sony xl2400 lamp replacement
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
Aug 28, 2009 | Sony (XL-2400) Projector Lamp for...
Sony 60" needs picture tube!
you can order the housing and lamp - naturally comes this way from sony - or order just the light(lamp) itself and save $100 - as long as you feel comfortable replacing it! chk these sites:
replacement lamp:
http://cgi.ebay.ca/SONY-XL-2000U-A1601753A-A-1601-753-A-XL2000U-LAMP-BULB_W0QQitemZ280241047600QQihZ018QQcategoryZ3320QQrdZ1QQssPageNameZWD4VQQcmdZViewItemQQ_trksidZp1744Q2em124
how to replace(you have to remove the bottom right grey plastic panel - just gently pull/pop it out corner by corner):
http://dlplampguide.com/xl2000u.html - at the bottom of the page it has a guide on how to change it
Jul 02, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Change the lamp/ didnt help, lamp indicator is on
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jack-
Nov 12, 2007 | HP Digital Projector Vp6120 Multimedia...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
