Hi waquashashmi,
A way to know if your Windows 7 system supports Aero or not is to look at
Windows Experience Index score. The score (both base score and subscore
for graphics component) should be equal or higher than 3.0 for Aero to
work. To view your Windows Experience Index, go to Control Panel ->
System and Security -> System, then click on "Windows Experience
Index".
To display Aero effects such as transparency in Windows 7, follow these steps:
- Make sure that Windows Experience Index has been calculated and computed.
- Click on Start menu.
- Type the following text into the Start Search box:
Aero
- Click on a search result listing under Control Panel group that named as the following:
Find and fix problems with transparency and other visual effects
Trick: If you don't see "Find and fix problems with transparency and other visual effects" in the search results, click on Control Panel to see all Aero related items in Control Panel.
- An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on Next button.
- The troubleshooting wizard will try to detect any problem by running
a series of checks against various components required to make Aero
works and running, such as video memory, Desktop Windows Manager (DWM)
service, color depth, theme, power settings and etc. At the end of the
analysis, the wizard will attempt to fix the issues related to Aero
service and restart the Aero feature.
If this information was helpful, please rate it.
Thank you for using Fixya,
Arun Zac
Do u have graphics card??
