SOURCE: my ge dishwasher won't run. it displays an error
hi heres what i found The 1 H is not a fault code it is the delay time of one hour.
SOURCE: vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
SOURCE: electrolux dishlex dishwasher
Here is the full story.......
Sale of fire-risk dishwashers banned
5:00AM Thursday July 24, 2008
New South Wales last night banned the sale of dishwasher brands fromAustralia's largest whitegoods supplier after the faulty machines werelinked to a string of home fires.
More than 26,000 Electrolux,Electrolux Dishlex and Westinghouse dishwashers sold in Australia andNew Zealand since April last year have a potential wiring fault.
TheNSW Fair Trading Minister, Linda Burney, said her department had beenalerted to 73 incidents involving the appliances, resulting inexcessive heat and kitchen fires.
Electrolux identified a fault with the dishwashers last year and has issued three appeals to consumers.
"Despitethis, Fair Trading has received reports that fires or incidentscontinue to occur," Ms Burney said. Up to 5000 of the dishwashersremain in households unchecked.
The minister said a wire connector within the appliances could cause plastic components to melt in the control panel.
The largest number of faulty washers are in NSW.
The state Commissioner of Fair Trading has moved to ban NSW retailers from selling their remaining stock of the appliances.
"The prohibition will ensure that any dishwashers not alreadyquarantined by Electrolux, which may be in retail outlets and not inthe possession of Electrolux, are not sold," Ms Burney said.
Theban and the recalls cover Electrolux, Electrolux Dishlex andWestinghouse washers with serial numbers ranging from 70700000 to72400000.
The NSW Government said consumers with one of thesemodels should stop using the machines immediately and contactElectrolux to arrange for a technician to fix the problem.
- AAP
This story was found at: http://www.nzherald.co.nz/section/1/story.cfm?c_id=1&objectid=10523214
SOURCE: How do I reset miele dishwasher - drain pipe now
Well first of all you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
Good Luck!!
Thanks for using FixYa!!
SOURCE: user manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
