Question about HP PSC 1315 All-In-One InkJet Printer
My HP 1315 has printing problems
When i turned it on shows a cartridge problems (color one), i replaced it , took it off, and the error persist, i cant even print in black. The E for error still showing and the light keeps blinking, anybody help me, please
  • Anonymous Nov 07, 2007
    paper feed problem
Pull out the cartridge and scrub its point with a simple eraser (common eraser for pencil)and fix again then check
Posted on Dec 04, 2006
Clean the print cartage
Posted on Jun 27, 2008
Take a hammer, and just one shot at HP 1315 will do it.
Posted on Dec 25, 2007
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
I changed the printer cartridges in a hp officejet 4315 and now it won't print-flashing error meesage "Cartridge Error:refer to device documentation to trouble shoot" What do I do? i
Good Day Sir, hope this will help you.
print cartridge troubleshooting for hp officejet 4315 :
1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles.
2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket.
3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side.
4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges.
5. If the self test report shows a problem, clean the print cartridges.
6. If the problem persists, clean the copper-colored contacts of the print cartridges.
7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
have a nice day.
7.
Jun 22, 2010 | HP Officejet 4315 All-in-One Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Error message everytime i print
the E error message is for 2 reasons.either its a paper jam in the printer or the cartridges r faulty.there r two cartridge 1colour and 1 black.as 1 of them may had gone faulty.just replace the cartridge and it will work properly.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Cartridge error light on
I just recently had the exact same problem. I went to the HP site and went to the Software and Drivers section for software and patches to download. I scrolled to the very bottom and downloaded the one marked "HP Print Cartridge Utility" and installed it. It fixed it in about 5 seconds. I hope that helps! Here's the link I used: http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&cc=us&lang=en&dlc=en&product=374568&os=228
Aug 18, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
1,875 people viewed this question
Clive
Clive
