Question about Sony Cyber-shot DSC-W30 Digital Camera
Problem with flash and a blinking message
When I turn on my camera, immediately on the screen "E:91:01" is blinking in white letters as well as an upside down arrow which blinks as well. Whenever I try to take pictures, the flash does not work. What can I do to fix this?
  • caseycahill Oct 26, 2008
    I have this problem and I have the tried to reset my camera using the "initialize" function on the menu. It seems to me like the flash is having trouble charging, camera works fine without flash. Anyone have an alternate solution?
  • bball698 Nov 16, 2008
    i have the same problem with the E:91:01 flashing and the flash symbol flashing. the flash will not go on and you can only take pictures when it is really bright out
I have also a DSC-W30 and I tried to basically reset to the default settings, going to Menu button, (Right Arrow), Setup, Down Arrow (2 times),Select with round button,Scroll down to Initialize and select OK.
You must inizializate your camera, but dont leave time adjusting the date. When your camera restart select any date quickly, then change the camera to the ISO option, to desactivate the flash temporarily, then change to AUTO option, and desactivate the flash. For the moment is the best option. Te problem may be ocasionated because your camera was in wet area and ocasionate a shortcut, but you need to verify if the problem is in the flash card, in any terminal, or in the motherboard.
Posted on Nov 16, 2008
Onkyo TX-SR 805 flashes message "Test - < - 42" when switched on at power button.
Hello, you seem to be in technician test mode. Unplug the receiver for an hour, turn on and perform a reset by holding vcr/dvr and then on/standby. This should resolve your issue. Thank you, Onkyo USA
Mar 01, 2017 | Onkyo Televison & Video
I have a black screen that says safe mode, safe mode with networkin , safe mode with command prompt and laast known good configuration but when i go to safe mode my computer just reboot all over again
This recycling/rebooting into this screen is normally caused an error (hardware or software).
You MUST turn off - Automatic Restart to see the error message.
Power down your laptop.
Press the power button to turn-on laptop.
Start pressing the F8 key immediately AFTER the DELL logo screen and BEFORE the windows screen.
You SHOULD be brought to the same screen as you described above but with an additional option: TURN-OFF automatic restart. Select this option and press ENTER.
Let laptop cycle and you should see blue background screen with white letters giving you information.
Please provide the ERROR message on screen BEFORE we can advise you any further.
Mar 30, 2011 | Dell Latitude D600 Notebook
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Apr 13, 2009 | Pure Digital Flip Video Ultra Camcorder
LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Oct 27, 2008 | Pentax K100D Digital Camera
Canon A 630 no flashing
Right now Canon's support section for their website is down.
What I'm looking for is to see if the flash was turned off by the control panel accidently. Most digital have a setting to turn it off.
Typically if the camera needs a flash and can't give you one you will get a warning message on the screen. If thats whats happening, then the sensor is working.
Sometimes weak batteries will cause the flash not to work because there may be enought current to run the screen and the shutter but not enough to run the flash at the same time. If you say the batteries are fine then that probably isn't the case.
If you have the book handy you might want to check the control panel settings and find the flash controls.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Turning off after taking a picture with a flash
Sorry but that is just because the flash is recharging.. It turns the screen off so it can charge the flash faster.. No worries it works fine :)
Jan 24, 2008 | Nikon Coolpix 4600 Digital Camera
Deleting from memory card
1. Set camera to playback mode and turn on.
2. Push "W" on zoom button (zoom out). (this will show you the index card)
3. Press the delete button (garbage can button)
4. Choose the top option "All In This Folder"
5. Confirm choice.
Nov 25, 2007 | Vivitar ViviCam 35 Digital Camera
Camera error
Check your manual for for error messages or go the the Tech Support website for Sony
May 23, 2007 | Sony Cyber-Shot DSC-P31 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
153 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
