Question about Refrigerators
Fridge not working. No light on inside fridge and not cooling.
  • 417 Answers
Sounds as if you have a power failure. If you are in the UK check the fuse in the plug it may have blown if not check if you have a switch thrown (off). Replace the fuse or reset the switch, if it goes off again you have a fault on the fridge.
Posted on Oct 21, 2008
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
