Ultra10 3750115 Motherboard displays watchdog reset intermittently
After extended sunvts loop, this system unexpectedly goes to "OK" prompt then displays watchdog reset. after isolation between system components, I'm sure that it was caused by a defective motherboard. how am i going to troubleshoot and repair (up to component level as much as possible) this motherboard? please help...
  • Anonymous Nov 08, 2008
    machine runs fine when watchdog unplugged from video surveillance card.
  • Erol Kane
    Erol Kane May 11, 2010
    why do u want to fix it yourself anyway if u arent expertised about than i advise u to get some pro help otherwise try some benchmark on it with cd or floppy tool for the specific board(if possible to get in other drives..?)
  • 781 Answers
Try this
replace M/board battery or rest BIOS to default and try again
Posted on Oct 27, 2008
How to hard reset digital watchdog DVR
Jason,
I found the following for DVR Vmax Flex: Reset procedure is as follows, Press and hold the OK button on the remote for 45 seconds, it will beep many times, a screen will pop up and ask you to reset, select YES. The reset will default it to factory, which is No Password at all. If this is not the info you're after, you can choose a method to contact Digital Watch Dog shown on their webpage:
http://digital-watchdog.com/
Apr 07, 2014 | Digital Watchdog Televison & Video
Resetting to factory settings trouble
You are caught in a loop. Have no recourse other than to use your restore disks and attempt a repair or new installation.
Sep 06, 2017 | Acer Aspire Z5600 PC Desktop
Lights remain red, battery 0%,and message is "pic watchdog emergency". What is wrong
OK, I found the problem. The ribbon cable to the sonar board from the motherboard was out just a fraction of an inch. Aslight nudge moved it in just a little, but enough I guess, it works now.
Dec 15, 2012 | Parrot AR.Drone 2.0
Windows shuts down unexpectedly
This problem has been solved. There was intermittent contact inside the power switch on the front of the case causing the motherboard to issue a shut-down request to the operating system. Switch replaced and system is now stable.
Oct 06, 2012 | ASUS M3N WS Motherboard
System reset by watchdog.tion
I've never seen a watchdog.tion error but watchdog errors can be set up on some CMOS when the 5v power from the power supply is bad.
I can't find anything on your specific error tho but I would try a different Power Supply Unit.
Jul 31, 2012 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Redout on jacuzzi spa model j340 has --- code.has been working
The condition you see on the topside control is known as "watchdog" Which usually means that the spa thinks it's "overheating"
Turn off the power to the spa for a couple of minutes, then restart, Watch the topside control if the temp. starts to climb & read a lot hotter than the actual water temp. Then it goes into watchdog, most likely you have a bad temp sensor. In some cases just resetting the spa will clear the watchdog & everything works fine. (Voltage fluctuations, "spikes" can freak out the electronics & the tub goes into watchdog to protect itself) If the spa immediately goes into watchdog when you reset it, you might have a bad board. (Let's pray it's not) 90% of the time it's a bad temp. sensor.
Jan 12, 2009 | Home
Emachine loop again
Try first of all 'Last good configuration'
If still no go consider what it is you have done latly in termso of installing new software or a new hardware device.
Remove the most recent.
Finally in Safe Mode go to Start/Programs/Accessories/System Tools/System Restore and reset the machine to a time before the problem started.
May 11, 2008 | eMachines T5274 Desktop PC
EMachine ailment
Fo you have the recoveryy disk?[May be called something else by E Machines
Dec 30, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
