Brother 8820D will not work through usb port - Office Equipment & Supplies
    Scholar:
  • 59 Answers
Hi coldstream here is a link that might explain the issue,
it's from the brother site.
altho it may not help with the problem it will explain why.
hope it helps.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000200/000035/faq000235_000.html?reg=us&c=us_ot&lang=en&prod=mfc8820d_us&Cat=2
Posted on Oct 21, 2008
3 Suggested Answers
  • 6 Answers
SOURCE: Brother 8820D
I purchased a direct replacement from e_techparts on ebay for under $10 + S&H, very simple replacement, just a few screws.
Posted on Apr 30, 2010
  • 4341 Answers
SOURCE: New computer is Windows 7
What you need to do is go to the brother website and get the install wizard for your printer and OS. Plug and play really does NOT work very well with printers, many features will not work correctly.
Posted on Apr 26, 2011
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
New computer is Windows 7 - 64 bit Printer is Brother MFC-8820D. Printer works fine - computer does not recognize the scanner feature of the MFC. Have tried both USB and LPT1 connection to the new...
I lost my network fax and scanning when I upgraded to Win 7 as Brother had no support for Win7 and this printer. Very disappointing.
However, I recently downloaded the MFC-8370DN install package from the Brother website and installed it on my Win7 64 bit Asus laptop. The installer couldn't find my MFC8820DN, but I manually entered the IP address (192.168.0.100 in my case). The install completed cleanly, after a reboot I can now start Brother Control Centre 3 and scan and fax from my 8820DN over the network. All good, no need to buy a new printer just yet...
Apr 26, 2011 | Brother MFC 8820D All-In-One Laser Printer
I scanned successfully. Next attempt says "Unable to initialize the scanner". I can't get past this (Brother 8820D)
the program you were scanning to probably didn't release the scanner. first thing to try is turn the scanner off for a minute or so and then back on.
Aug 13, 2009 | Brother MFC 8820D All-In-One Laser Printer
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
My printer says doc cover open on a mfc 8820d how should i fix.
You have to close the ADF. If the ADF is closed, then the left hinge is probably broken. Look for "MFC-8820D hinge" to find the solution in FixYa.
Jan 10, 2009 | Brother MFC 8820D All-In-One Laser Printer
Poor printing quality after replacing drum
Have you checked to see if your setting for color is set to grayscale?
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC-8820D Machine Error A
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Oct 02, 2006 | Brother MFC-8820D Laser Flatbel...
76 people viewed this question
jasbo
jasbo
