Question about Synology Disk Station DS207+ (DS207PLUS) Network Storage Server
Repeated hard disk failure and slow internal webserver
I've had this product for about 3 months. During that time the second hard disk has failed twice and been replaced with a brand new unit. My third hard disk failed this week - it was Western Digital rather than Seagate, and I have little confidence in the unit. Is this likely to be a fault with the Disk Station itself or is there anything else I can do apart from return for warranty replacement.
I've also found the unit to be incredibly slow when running as a webserver, taking over 15 seconds to generate a webpage using PHP and SQL compared with 2-3 seconds on my own PC's builtin webserver.
Functionality of the unit and associated software appears to be excellent apart from these two critical problems.
  • momack May 01, 2009
    I have the same problem with Synology Cube 407e. Killed 7 disks already.
I have a simular problem with my DS207+. My second (sic!) volume failed especially when copying a lot.
But as I was using RAID1, I just repaired it and lived with it for the next months.
But now I want to have "Basic" drives.
I found this:
http://www.synology.com/enu/forum/viewtopic.php?f=7&t=8284&p=44638
I will try and get hold of those cables.
If your third disk is failing again, it seems like a cable issue as well.
regards,
Markus
Posted on Nov 17, 2008
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I just experienced my third ST3500418AS failure in 3 months. My disks are in RAID10 (1+0) configuration, so I've just been returning the drives, and the RAID rebuilds, but what's going on? I get...
Since you have so often problems, I suggest to take a look at the controller also (firmware etc). If it's possible use another one (in case of independent controller). A good idea is to check for hard disk firmware update from official seagate site.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Seagate ST3500418AS 500GB 7200RPM SATA...
Smart test failed on the drive
A smart failure warning is an internal hard disk drive self-diagnostic that will help predict a failure of the hard disk drive. Any system that is displaying a SMART error should immediately have any important data backed up as the drive is not reliable and is impending failure if it hasn't failed already.
Resolution is hard disk drive replacement, Generally around $100 depending on size and speed of replacement HDD
Jan 25, 2011 | HP Pavilion Slimline s3700y Desktop,...
I cant start my dell latitude d410, more precise i can start it in like 1 time out of 50 tries, regardless if i plug in battery or try just with ac power. it lites 1st led for main power, just flashes...
From what you describe, the boot failure is most likely a failing hard disk drive that is very slow to get up to speed. As far as the battery, since the D410 has been out of production for several years and the battery expectancy is about 30 months, the battery and HDD like both need replacement
Sep 24, 2010 | Dell Latitude D410 Notebook
Hard disk very slow and restart.
Seagate is known for hard drive failures. The S.M.A.R.T. feature may warn you that the drive is failing. This is not uncommon and is most likely the case of why it is going slow now. You should contact seagate ASAP to see if they can give you a replacement.
Jan 31, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard Disk Failure
as the hard drive have movable parts it will fail one day.
If you defragement your hard drive monthly then it will take good care of your hard drive.
As the inspector is saying you should be ready for failure of your hard drive and you should back up your data.
Jun 19, 2008 | Microsoft Windows Vista Ultimate Edition
Samsug HT-SK5 fails with 'Protection' on display
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
May 28, 2008 | Samsung HT-SK5 System
Samsung sp2004c drive failure
My guess is that your hard drive is corrupted. If you have any extra hard drives (external or internal), try replacing your current hard drive with that one, and see if that works. If it does, you may have to take your Hard Drive to a computer shop to have it recovered.
If that doesn't work, then something corrupted your operating system. I would re-install the operating system (reformat may not be necessary, but is always better than just a reinstall, although you do lose all of your information during a reformat), and then try.
Feb 10, 2008 | Samsung SpinPoint P120S (SP2004C) 200 GB...
Synology Disk Station DS207+ (DS207PLUS) Network Storage Server Logo
913 people viewed this question
Top Synology Computers & Internet Experts
David Payne
David Payne
Are you a Synology Computer and Internet Expert? Answer questions, earn points and help others
