Behringer djx700 mixer volume comes from left side only master volume looks like it was gained to max and blown the pre amp i am pressuming how can i fix it and is it the pre amp adjusts master and crackles loudly and spikes to red by just touching master volume
  • 1,512 Answers
Hi danjan
Sounds like you have a faulty master level control, or dry solder joints connecting it. There are a few things that you can do to sure this. .
  1. Pop the unit apart so you can get access to the control solder side of the printed Circuit Board.
  2. First, visually check the soldering to the control where it connects to the board,
  3. If soldering to it looks ok, then try a squirt of CRC 2-26 contact cleaner lubricant into the internals of the master control.
  4. Before replacing it you need to be sure that the pot is faulty is to look for audio in the center wiper of connection of the control. You will need some test gear to pursue this level of diagnosis
  5. If you have audio in and out from the pot, then there is a failure after the pot in the summing amplifier stages. No audio into the pot points to the stage prior to it.
If you have no experience with this sort of repair work to high density surface mount circuitry, then I strongly urge you get an audio tech to have a look at it for you;:) This sort of repair expect to set you set you back $40-80 across my workbench, depending on what needed to be done. Good Luck
regards
robotek
Posted on Oct 21, 2008
Behringer djx700 has no bass
Check that all the eqs are set not to cut bass, check there are no effects on and that the XPQ is off. If you still have the problem how sure are you there is no bass coming from the mixer? Have you tried it with another amp? We had one hire customer who had the same problem you describe and his amp had a crossover and it was set to act as a mid/top amp and wasn't giving him any bass, unsurprisingly, switching it back to full range sorted it.
Dec 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Im not getting anything from my djx700 master output, getting sound from booth output. what could this be
The first thing I would look at is the kill switches on each side, make sure these are not pressed. Also make sure the master fader is up. I would disconnect anything that may be plugged into the effects loop send and return. Make sure the main outs are plugged in correctly, the main master outs should go to a power amp, this unit appears to be a unpowered unit. Make sure you are using the proper cables to avoid damage, lookup and understand the difference in speaker cords and instrument cords and place them properly. Also make sure the "assign A" and "assign B" are positioned correctly. Hope this helps but, if you give me a little info on how you are using this unit, I could help you further, please.
Mar 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Djx700 Headphone (cue) Problem. Please help.
Have a look at page 4 of your manual under the Monitor section, mode switch. Manual is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf The mode switch may be faulty or the mix control may be faulty.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
One side is louder than other
You have had a pre amp or final amp go out. If you have any electronic background, you can open the unit up and compare the voltages on the side that is working and find the problem with the other side. Most of these stereo boards have the same componets one side that is on the other. Hope that makes sense. Hope this is helpful.
Oct 02, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Apr 24, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Connecting a behringer djx700 mixer to a panasonic amp
The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
Check that first and get back to us if you still have problems/questions.
Dan
Aug 21, 2008 | Audio Players & Recorders
118 people viewed this question
 Grubhead
Grubhead
