Question about ASUS Computers & Internet
I have ASUS A3AC laptop bought in Australia. Now I am facing problem with AC power adopter I believe. Laptop only power up if i push it hard and try few times to connect and re-connect. Due to faulty connection battery also don't gt charged.What is the solution for this problem? If I buy a new adopter does it work or any problem internally?
  • skseva Oct 21, 2008
    I did bought the US compatible plugs already for Aussie adapter.The laptop started doing like this since last month. Any more suggestions.
    Guru:
  • 859 Answers
All you need is a power plug adapter. At Radio Shack you can find one for US plugs to any other plug in another country. They will be able to order a reverse adapter, one to adapt Aussie plugs to US plugs. I'd start there and they'll find you one no doubt about it.
Regards,
Worldvet
Posted on Oct 21, 2008
  • Glenn Rogers
    Glenn Rogers Oct 21, 2008
    Yes, there must be an issue with the adapter aussie male to female /male US adapter. This could be the only problem especially if you have to push hard to get a hookup.
    Sorry, but this has got to be the problem. I have too much experience in this field to believe otherwise.
    Worldvet
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Adapter schematic
if u want schematic of laptop adopter then u should sell first what is the volt of adopter is generating for your laptop.
then you search on google.
Nov 28, 2013 | ASUS Computers & Internet
Unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Sep 21, 2012 | ASUS Computers & Internet
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
WHAT IS THE MAXIMUM MEMORY CAPACITY THAT MY ASUS A3AC CAN HAVE? WHAT TYPE OF MEMORY WILL GO INTO THE ASUS A3AC? What maximum hard disk size can the ASUS A3Ac running Windows XP can have?
max memory is 2GB ddr2 533 also known as pc4200.
If you dont have sp1 or later, 137gb is the maximum HD your system will see. If you have service packs installed then you can have as big a HD as you want. You may need to use a disc partitioning program to get the full use out of large HD's
Sep 03, 2010 | ASUS A3Ac Notebook
Plugged in Laptop won't turn on.
Hi there, your computer may have a power problem you should first plug the AC power adopter into a different wall outlet, and check the light which indicate if the computer receiving power if the problem still exist you should check the AC power adopter to see if it is working. You can do so by using it on another computer just like yours,and should also try another AC power adopter on your computer just like the present one,if your computer work this mean the problem was the adopter.If the problem still exist then it may be the power supply or the motherboard has a fault and need to be replace
May 19, 2010 | HP Pavilion dv8000t Notebook
My laptop asus a3a, wont start up when
You hard drive is possibly on the verge of failing completely, I suggest you back up data as soon as you can.
The hard drive may only need re-seating, but only do this after your data backup.
Apr 02, 2009 | ASUS A3Ac Notebook
Asus A3AC - how to remove keyboard
Flip the laptop over, there is a hole scre in a hole on the graphics card and cpu cover.
It is marked with a K>.
Remove that screw and flip the laptop back over.
At the top of the keyboard over the f2 key, between F5 and F6 F10 and the INS buttons.
Pop these over to release and then there are two on the sides near Tab and PgUp.
Slowly lift the keyboard up don't yank or pull hard.
there is a data cable is on the lower left.
Slide the lock bar down and release the data cable.
Dec 24, 2008 | ASUS A3Ac Notebook
Computers & Internet Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
