Need a manual for this machine
SOURCE: I have a gestetner dsc460 copier. I am going to
okay your machine has the finisher option and punch option? if so when you go to print click file, then print. when your window opens for the printers select the gestetner. then choose properties. then choose printing prfeerences. then choose punch
SOURCE: how do you install an ethernet card on a gestetner DSM645 copier/
Are you trying to install an ethernet or "NIC" card in order to turn the machine into a printer? If so then you need more than a nic card. You would also need a ROM chip, Print controller, Hard Disk Drive and the buttons for the control panel.
If you are just replacing a NIC and expanding the memory then that is possible but the instructions to do so would be more than could be typed up here.
SOURCE: how much is gestetner 3222 worth
This machine is made by Ricoh and the same as a model Aficio 220. Pretty old and not worth much. If it runs and makes nice copies then $300 to $400. If it does not work or makes poor copies then next to nothing. I specialize in buying/selling used refurbished copiers and am very familiar with this model.
Good Luck and Thank You for using Fixya.
SOURCE: Faxing with Gestetner DSm 635 sp Copier
There is a fax module that you can purchase to be able to fax from the copier. If it is already installed, you will see two phone jacks on the rear side of the machine. One will be labeled "Line" and one will be labeled "Tel" -- if you plug a phone cord from the jack in the wall to the jack labeled "Line," your copier is all ready to fax.
On the operation panel, there should be a button on the left labeled "Fax" under the buttons labeled "Copier" and "Document Server" -- press that button to get to the fax screen.
Hope that helps!
