Question about MSI 915P Combo-FR Motherboard
PC Hangs at POST
Hi There, I know there was a similar problem to this one posted just the other day, but this does seem stranger. When I put my system together (it's a P4 3.2ghz, Video card is a Nvidia 7600GT, memory is 1gb PC3200 DDR, 260gb SATA HDD). It booted fine to the boot options screen asking me to go into safe mode etc. Probably because it was not a fresh XP installation for the new machine. Anyway I went into the BIOS and the only option I changed was to select the fail-safe settings. Now when I goto boot the machine it hangs just after the memory test and I cannot access the BIOS, my hardware seems to be fine as I have a display, it shows my CPU as correct and the memory as ok, I have tried resetting the CMOS with and without the battery in and changed the jumper even for over three hours but to no avail, I have tried MSI Tech support they were no help. So I was wondering if anyone can shed any light on this for me Thanks very much John
  • Addieismadi Apr 07, 2008
    hi there ! I wrongly reset my bios now im stucked at boot up. cant press the delete button to go setup. I t just hang right after processor checked. Pls help how to reset bios. Try mostly eveything taking battery,cmos pull out cables still stucked the same spot.
  • 432 Answers
Unplug the harddrive data cable,take out any cards that are plugged in, (ie., sound card, tv card, modem, etc..) and turn on the pc and see if you can get into the BIOS. If you can, go through your BIOS settings one by one and save settings. Plug the HDD back in and turn on the PC. Don,t insert the cards just yet. If it boots to windows your on your way.
Posted on Jun 22, 2007
SOURCE:
After putting in my online banking ID, why wont it accept my password.
Contact your bank. If you actually post enough information for somebody to help, you have probably posted enough information to allow a total stranger access to your account.
Feb 16, 2017 | Online Computers & Internet
My dg31pr gets stuck on bios screen and no matter how many times i restart it it keeps getting stuck there.if i m lucky after an hour or so it starts.i really need help with this problem.my pc has 500 gb...
Hi.
Fisrt of all remove the 2 external hard drives from the computer, boot the computer up and see if it still hangs on the post information screen.
If it doesn't then the BIOS has a problem detecting the externals thus why its hanging on the BIOS.
If it still hangs try to completely reset the BIOS either by putting the plastic jumper in the "on" possition and turning the computer on. The jumper is located to the left hand side of the "Front Header" (power switch, reset etc) or remove the power cord from the rear of the computer and then take out the motherboard battery and leave it out for 20 minutes.
That should clear the CMOS and reset the BIOS and stop it hanging on the post screen. Remember that once you have done this you will need to set the date and time.
Regards.
Jun 15, 2011 | Computers & Internet
Sometimes I want to identify a person or a object via a picture I have from my camera or my computer. I don't know of an "ask it" site that allows you to post pictures. They do allow you to post another...
Ask it Site, Do not allow to Post Another WEB SITE?
Kindly explain the same in Detail, so that i could help you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 14, 2010 | Computers & Internet
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
My acer travelmate 2500 hangs on post.
Please format your laptop.Install all the drivers properly
Jul 14, 2009 | Computers & Internet
ECS 6100SM-M hangs on POST
Check memory, remove or replace sticks of memory with just one piece in the slot closes to the CPU. Now try a power on and see if it boots. You have at lease one good stick of memory to boot.
May 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computer doesn't start normally. Hangs everytime.
your battery is dead change the battery the bios is not saving your setting due to battery and popping up to find hard drive again it is using the defaults settings
May 07, 2009 | Dell Dimension 3100 PC Desktop
System will.not post
Can anyone help me pls. fix my problem. My P5PE-VM Asus Motherboard having a problem error loading operating system. I replace my RAM, power supply and hard disk drive but seem's the error is not fix....I'm out of idea can anyone knows it and solve the problem.. I appreciate to thanks in advace!!!..
May 10, 2008 | Computers & Internet
No boot - constant fan
Update from my immediate post today: I've looked at other post that is suggesting memory or battery problem. To my surprise, after removing one memory from bank2 of DIMM, the PC came back to life! Whenever the second bank has either memory stick in it, it will stuck. So I ends up with half the memory, but get my system back. Not sure how long this will last though.
I Had similar history as the initial post: runs OK, and started random shut down 2 days before final stall. I am putting back my HDD and system, should be working, for now at least.
Feb 16, 2008 | Shuttle ST20G5 Socket 939 Barebone Kit /...
My sony has systm error 32
Hi, Can you pls give some more info: System 32 error after POST before Windows or System 32 error, after windows partially booted? Offhand, if the error is after POST before Windows boot, it is a hardware problem based on motherboard built-in diagnostic program: you may have to check/repalce reseat/connect memory, video card, hard drive; If it is after Windows partially boots, then chances are it is a driver problem; try running in safe mode and check at which points it stops or hangs. Hope this give you some idea. Pls post/comment back if you need further information. Good luck and kind regards.
Aug 12, 2007 | Sony VAIO PCV-E518DS PC Desktop
MSI 915P Combo-FR Motherboard Logo
129 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
