Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Cobra 29 NW LTD CLASSIC NIGHTWATCH
Transmitting on the radio seems to break up every once in awhile, even when I switch mics it still does it.. Every so often, the radio starts making a popping, crackling sound, I can turn it off and back on and its gone for about 60 seconds.. Any idea?
  • freddy0872 Oct 22, 2008
    I got the same problem. i just got mine today. i have no idea. and another thing with mine is that the PA speaker is extremely quiet. worse than the **** CB i had before this
  • josh551 Dec 04, 2008
    I have the same problem also,
    on mine I get a **** load of static sometimes I have to turn the radio off.
    Problem Solver:
  • 14 Answers
Dear RobertTx,
Sounds like you may have a leaky or shorted capacitor somewhere in the power circuits, or a defective transistor in the same circuits since it affects both the transmitter and receiver.
Common problems with receive and transmit intermittance can also be the antenna or its connections. The fact that it goes away if the radio is turned off, then on again after a short time points to something common in the power supply section. Unless you have test equipment and a working knowledge of electronics it will be difficult for you to troubleshoot on your own.
Jules
Posted on Nov 05, 2008
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Information for ordering parts
find a old cobra radio and get the switch out of it or go to your local cb shop and you should be able to get one.
Mar 06, 2009 | Cobra 29 LTD CB Radio
Radio stays transmiting after mic released
What happens if you "key up" and "let off" and the transmitter "hangs", you remove the microphone plug from the Cobra ?
Will it still be transmitting or will it stop ?
If it stops, the problem is in the microphone with a "hanging" switch which you can easily clean or replace.
Iif it keeps transmitting while the mike is disconnected, there is a problem with the Rx/Tx switching circuit. This needs further investigation by use of a circuit diagram.
Feb 13, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
I can hear others but when i talk noone hears me
Try switching a different mic, sometimes the transmitting wire comes loose inside the connector. If you are handy enough, you can even unscrew those two tiny screws on the end of the mic cord and see if a wire is loose and if so, solder it back into place.
Oct 04, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Mar 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
207 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
