Question about Brother LS-2125 Mechanical Sewing Machine
Getting jam all the thread and needle do not mooving
When i am stiching all the threads become jam and needle is not moving
Make sure your needle is not dul you may need to adjust your tension as well.
Posted on Oct 21, 2008
Jams up after a couple stiches
It's jamming up underneath your bobbin is in backwards turn it over.
Aug 14, 2016 | Sewing Machines
Kenmore will only stich three times then jams all link gone just had serviced 5mths ago
try changing needles, i had the same problem and i put new needles in and it works great now.
Dec 17, 2012 | Sewing Machines
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
Needle becomes in threaded after 3 stiches
try changing the needle
check for burrs in the bobbin area
check for burrs on the needle plate
try rethreading with a different spool of thread for the top & bobbin
Oct 15, 2012 | Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
I have a brother model 385 1551600 serial 03024885 I have not used it in about 3years. My problem is when i start to sew it will stich maybe a inch then the thread jam up in the bobbin area i'm th
change the needle
clean under the needle plate area & in bobbin area for loose threads & lint
make sure the thread isn't coming off the thread take up lever
since the machne has not been used in about 3 years it may need to be serviced
Mar 17, 2012 | Brother Sewing Machines
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
Take out the thread. Now cut the end of thread using a pair scissors. Now try that again. Once i had the same problem and later found out that the uneven end of the thread caused problem by refusig to move around freely hence preventing the stich formation
Dec 02, 2010 | Janome Sewing Machines
Machine Jamming after a few stiches
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
keep a check on the thread take up lever to make sure the thread doesn't come off of it
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Brother CE4000 Computerized Sewing Machine
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
