Question about Kodak EasyShare M853 Digital Camera
Kodak camera 8.2 m853
When you press the on button the lens won't open the camera won't come on.
  • Anonymous Nov 25, 2008
    light blinks ten times, but camera does not power on.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Posted on Oct 21, 2012
  • 153 Answers
SOURCE: Dropped camera. lens open and crooked
Sorry to say you have broken the lens, replacement of the lens is the only practical repair and if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Posted on Jun 01, 2008
targis55
SOURCE: Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
My daughter's phone got slept on. Lens was not square and would not retract. After reading all the stories of woe I suspected it was alost cause. I pushed on the bigger piece of the lens till it clicked and it immediately closed up and worked no problem. If you still have warrantee let Kodak look after it, if not then brute force did work. Just push up in the direction it looks like it needs to go.
Posted on Jun 29, 2008
praky16
  • 744 Answers
SOURCE: V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Posted on Feb 12, 2009
t00nz
  • 4738 Answers
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 05, 2009
praky16
  • 744 Answers
SOURCE: Camera Won't Stay On.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes....
thank u
rate me
Posted on Jun 01, 2009
Kodak M853 black screen
the Screen LCD is faulty. You must replace and dissasembly your camera, for fix it. you have 2 optione a) do it yourself or b) go to the repair shop for fix it.
God bless you
Jul 21, 2012 | Kodak EasyShare M853 Digital Camera
Lens won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 14, 2011 | Kodak EasyShare M853 Digital Camera
Kodak M853. The lense will not retract, and the outer lense is crooked.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 15, 2011 | Kodak EasyShare M853 Digital Camera
The lens does not close properly.
insert new batteries press on and off two to three times ......apply little pressure on button and hold it for few seconds .....the lens will get closed ......
Feb 09, 2009 | Kodak EasyShare M853 Digital Camera
Lens error
It could be jammed or when you turn it on, your finger or somthing is in way of it opening all the way.
Aug 05, 2008 | Kodak EasyShare M853 Digital Camera
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
Jul 25, 2008 | Kodak EasyShare M853 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
