I cant install my Belkin N Wireless Router
When i try to install my router it says that it couldn't connect to the router via any of the network adapters on this computer even after i checked that everything was ok and I tryed restarting everything and that didn't help either. What should I do?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..start with the control panel, network connections, and make sure that the network connections are active from the computer side..
    Master:
  • 538 Answers
Ahuh
Posted on Oct 21, 2008
I cannot connect to my belkin connect n150 router after enabling it as an access point. Green light shows up on router and wireless network shows up but no connection when clicked. I cant connect via
Pretty sure you have to have at least one router in gateway mode to connect to the internet. An AP allows wireless devices to connect to a wired segment. The same as a router in gateway mode. AP mode has the benefit of extending a networks wireless range. If this is your only device leave it in gateway mode.
Jan 28, 2013 | Belkin Basic Wireless Router
I can't connect my ipod touch to my wireless network via my belkin router even though it says its connected
try disabling security in the roter and try to connect via wireless or try with 64bit wep security and change the ssid of router u will get connected
Dec 09, 2009 | Belkin (F5D7231-4) Wireless Router
Cant rember password
Your wireless router is prompting you for a password in order to log onto your network. If you do not remember your password, you can reset the routers' configuration by holding down the reset button on the back of the router, and you can then use the default user name and password to change the settings. HOWEVER, you will lose all of your network settings so if you have multiple devices connected via wireless,they will also have to be reset.
If you need help re-configuring your router, visit the router manufacturer's web page. There should be a tutorial to walk you through the process.
If you happen to have a Linksys wireless router, here is their page: http://www.wikihow.com/Reset-a-Linksys-Router
Sep 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
David Payne
David Payne
