Question about Canon MP520 All-In-One InkJet Photo Printer
The following ink has run out
After refill ink tank, the printer show Error U163. "The following ink has run out. replace the ink tank."
  • 421 Answers
Press and hold stop/reset for 5 seconds to disable the function. Printer should now print
Posted on Dec 05, 2008
  • 1 more comment
  • ColossalP May 23, 2011
    Thanks for the tip! Very helpful in dealing with error messages that come from using refilled cartridges. My printer likes to pretend they're out of ink when they're not!
  • cipriano_mar Jul 07, 2011
    thanks for this tip!! this very helpful!!!
  • John Lampronikos
    John Lampronikos Dec 14, 2011
    Thank you so much..I hate crazy pc/software issues
What does it mean check ink u163 0f canon pixma 360
re filled inks have being installed that's why u get u163 or u162 error
try following to resolve yours error u163 or u162
  1. Turn off your printer and turn it on again.
  2. After the printer initializes, try to copy or print something. The error will appear again.
  3. When the error is displayed on the display panel of the printer, press and hold the STOP/RESET button and wait until it self restarts.
  4. Release the STOP/RESET button while the printer is restarting.
  5. Wait for a few seconds and the pending print jobs will commence.
Jul 22, 2014 | Canon Pixma MX360 Printer
I refilled the catridge and inserted its showings a message check color ink
Press and hold the Stop/Reset button until the message disappears. You will have to do this every time you insert a "new" refilled cartridge.
Sep 15, 2012 | Canon Pixma Mx340 All-in-one Inkjet...
I have canon pixma 310 its say chech ink u163 what thats mean
Good Day Sandip920!
Error U163 means, the printer detected that your black ink cartridge has been refilled with new ink.
It is very easy to clear this error and keep your printer printing.
How?
1. Turn on your printer.
2. When error U163 appears, press and hold the STOP/RESET buton on the printer. Hold it down until the printer self restart and initialize.
3. if after U163 is cleared off and appear another error, U162, press and hold again the STOP/RESET button and wait till printer self restart and initialize again.
Hope this helps!
Don't forget to rate my answer.
Thanks for asking Fixya.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
I replaced the original cartridges with CANON., still it shows CHECK INK U163 and error light. What could be the problem.
Reset the printer ink level detection.
Press and hold down STOP/RESET button and wait for the printer to restart.
Release button when printer completely initialize (This will clear the U163 error)
Hope that is what you need to know
Sep 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
U163 problem
More the likley, your printer's manufacturer does not allow for the use of refilled ink cartridges on their products.
Please purchase a factory new cartridge from the manufactuer of the printer.
Aug 14, 2009 | Office Equipment & Supplies
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon MP520 All-In-One InkJet Photo Printer Logo
4,546 people viewed this question
old marine
old marine
