I get an error message when trying to connect to the internet,, is there a fix for this?
  • dannyw1968 Oct 21, 2008
    internal error, 80and a bunch of other numbers
  • 154 Answers
What is the error message?
Posted on Oct 21, 2008
What is this error dns_probe_finished_no_internet and how can i fix it
It has tried to find the internet connection and failed.
Look at you internet cable and whether the cable modem etc. is working.
Mar 18, 2015 | Computers & Internet
Dns error laptop
    • 1 Refresh the page that failed to load. If the page reloads, you just had a momentary lapse in service that happens with most providers. Between each following step, try refreshing the page to see if the problem is resolved.
    • 2 Check the page address you typed into the address bar to make sure it is spelled right. An error in the URL address could cause this error message.
    • Sponsored Links
    • 3 Go to your connection settings and make sure the settings match those of your Internet serviceicon1.png provider or local area network. Do this by clicking on Tools on the toolbar, then Internet Options. Under the Connections tab, click Settings.
    • 4 Click the "Detect Network Settings" link on the Interneticon1.png Explorer page accompanying the error message to let Windows try and find an optimum connection.
    • 5 Download DNS error fix softwareicon1.png off the Internet if no other option works (see Resources). The software is free on some websites and should be able to identify the problem and correct it.
Nov 21, 2013 | Lenovo Computers & Internet
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
How do I fix this problem? I get this error message when trying to login to messenger. "We can't sign you in to Yahoo! Messenger. There might be a problem with your Internet connection. Make sure your...
Please downlaod latest messanger and install in computer which can fix issue
link for latest yahoo.messanger
please rate the service if issue resolve
Thanks for using Fixya
Apr 02, 2010 | Yahoo Messenger
Internet is connected, cannot get on browser or ymessenger
Try connecting to yahoo by clicking the link below:
Jun 12, 2009 | Yahoo Messenger
Error occurs during start operation (80010514)
do you have your ps3 connected to the internet via wireless or Ethernet normally when a playstation is connected to the internet and if for some reason it can't connect to the internet the next time the system is on it will show this messages also did you try to download an update and installed and if the download did not finish correctly it also show this messages
May 24, 2009 | Sony PlayStation® 3 (80GB) Console
Error sending text messages from my computer to my friends cell
It is an internet problem as it seems. Normally you can send messages to only one mobile once if the reply comes than you can continue chatting. But as it is giving you any server error and if your internet connection is running than try to go to the preferences of the yahoo check the connection it is using. If it is using the same connection as your browser.
If you like my advice rate me thanks.
Mar 11, 2009 | Yahoo Messenger
Error code 80072745
This error is fixed by the solution here.
Nov 05, 2008 | Microsoft Windows Live Messanger
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
