Question about Lands Phones
Change of dialing mode
Changing dialing mode from tone to pulse
  • tracyl13 Dec 25, 2008
    I have looked through the instruction manual and cannot find this anywhere. I hve contacted Vtech and have yet to receive response. We still have a rotary phone line and if I cannot change the phone setting to pulse, we cannot dial out.
    Sergeant:
  • 154 Answers
Just go by the program instruction in yior manual
its very simple
Posted on Oct 21, 2008
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Changing to pulse
Enter SetUp. Look for Global setup. You have the options Area code, Dial Mode. This last option is the one that allows you to change between Pulse and Tone dialing.
Dec 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Lands Phones Logo
1,083 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
