Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Disc indicator flashes
The disc indicator is flashing while recording. Never happened before. What did I do wrong?
    Sergeant:
  • 154 Answers
Lens problem
clean the lens using a lens cleaning disc
Posted on Oct 21, 2008
Hi,I have just bought a Denon dn m991r second hand and I am having problems recording on analog.I press record and DIGITAL IN starts flashing on display,I press play/pause button but nothing happens no...
Go here - http://www.minidisc.org/part_Denon_DN-M991R.html . Get the owner's manual. Read it.
The preset mode changes whether you record analog or digital.
Assuming nothing is jamming or is bent, the weak eject is probably why the guy sold it to you. It can't hurt to take the cover off and watch what happens.
Aug 05, 2012 | Denon DN-M991R Mini Disc Player
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
Mar 26, 2012 | Audio Players & Recorders
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
Dvd recorder Emerson EWR10D4 will not recognize any dvd disc will only play every blank disc i have tried it says error cannot record on this disc have tried multipl kind so disc and speeds.This is the...
If the person did a firmware upgrade,he might have flashed it with a bad firmware,or the wrong one.You will need to get the original firmware and reflash it and see if that helps.
The other option is the laser might have gone bad in it.
Sep 02, 2009 | Emerson Televison & Video
Jb 940 md player. Recording a full disc, always results in playback stopping around 38 mins. previously recorded discs will play back ok, so suspect record process not completing. When played in spare...
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Apr 11, 2009 | Sony MDS-JB940 Mini Disc Player
Dvd recorder will not play or record
≥The disc is scratched. Use another disc.
≥The disc is dirty.
≥You inserted an incompatible disc
Dec 28, 2008 | LG RH188
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
Dec 03, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Panasonic Camcorder
thats an indication that no disc or wrong type of disc is present. Have you tryed to clean the laser lens>> or using the approved lens cleaner for this unit?? try it and see you may be surprised. good luck
Apr 25, 2006 | Panasonic PV-DV53 Mini DV Digital...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
