Question about Cell Phones
WATER CORROSION IN CELL PHONE - Cell Phones
  • yale0093 Dec 25, 2008
    water damage cellphone,how do i get the phone to power on and dial?
Usually soak your phone in rice. That will soak all the water in. Then remove battery, sim card, phone case, charms etc. and place in new a new bowl of rice. After letting sit in the bowl for one hour remove and clean the inside of the phone without the battery in with a baby wipe, soapy towel, hand sanitizer which will kill the germs causing the corrosion. After wiping baby wipe, soapy towel, hand sanitizer off with a little water let sit again in rice.
Posted on Jan 27, 2011
    Sergeant:
  • 154 Answers
That is rare.
prevent your phone from water
Posted on Oct 21, 2008
How do I fix a ZTE N861form water damage
Put the phone in a bag of rice for 2-3 days the rice should absorb most of the water. If you have any technical knowhow when it comes to cell phones then take the phone apart look at all the electrical boards and see if there is any corrosion on the solder joints/points if there is, remove the corrosion using Isopropyl alcohol(Rubbing alcohol) try to use 90% if possible then put the phone back together. I do not recommend you disassemble your cell phone without prior knowledge or experience doing so.
Feb 19, 2015 | ZTE Cell Phones
I soaked my phone and now it works fine but has an all white screen.
might some corrosion affects the board dispay connector or lcd connector,probably needs replacement
Feb 25, 2012 | Pantech Matrix Cell Phone
Phone was in the water for about 49 minutes what should I do Will my phone work again or should I dump it
pretty much. the ICs by now has corrosion already if you did not open it up and air dried it. It would be more expensive if you have this fixed.
Nov 03, 2010 | LG GD510 Cell Phone
Dropped phone in salt water turns on but buttons wont work
Your phone is probably cooked ... salt water is highly corrosive. Your service provider may be able to clean it ... but it is probably damaged beyond economical repair. The sooner you get your phone into the professionals, the better your chances of recovery. Be prepared to replace it.
Thanks for your interest in FixYa.com Please remember to evaluate this response.
Thank you
Jul 04, 2010 | Pantech Slate Cell Phone
Iphone touch screen broke when i droped it in water
try to disassemble and replace the battery and screeen as soon as you can, to avoid corrosion in your iPhone motherboard.
in the picture you can see the corrosion in an iPhone 3G motherboard, after 12 hours the device was exposed to water.
So please hurry up, and get you iPhone dismantled and dried.
Aug 28, 2009 | Apple iPhone Smartphone
Dropped my phone in water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the phone got wet and exposed to liquid, it needs service. It will lead to corrosion that may damage the phone’s mother board.
Jul 17, 2009 | Samsung Cell Phones
No power
Strip down the cell but you should have removed the battery after getting it out of water,i find most cells recover if dissasembled a.s.a.p and cleaned out then the circutboard can be wiped down with a lubricant like wd40 using a fine small artist paintbrush and swabbing with a cotton cloth gently to remove moisture.The residue wd40 displaces corrosion that may occur in future.
Dec 09, 2008 | Sony Ericsson K610i Cellular Phone
Broken nokia 6600 ... please i need your help!! :(
Water, cellphones worst enemy, i sugest you to buy a new one as the damage of water occurs just withing 2 minutes of the contact, this is because the water starts reacting with the metals inside that have electriciy on them that often creates corrosion and that corrosion is conductive. if you want to minimise damage next time i suggest you to IMEDIATLY remove the battery and put your phone in a sock or piece of clothe and swing it round to remove the water from its guts. this way i have saved some phones afterwards i used a hair dryer to dry them up as soon as possible.
Sep 18, 2007 | Nokia 6600
BACKLIGHT STILL ON
How wet did it get? Was it submerged? The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years. If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol.
Jul 08, 2007 | Pantech C300 Cellular Phone
Cell Phones Logo
799 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
