Bosch SHU9915UC Dishwasher Logo
Posted on Apr 04, 2017
Water puddle on bottom of bosch dishwasher. I put them in cleaner then they come out. I even ran the dishwasher two more cycles without soap so I wouldn't have all the white streaks but....
Dishes come out of the wash cycle wet, dirty, streaky, and disgusting.  I put them in cleaner then they come out.  I even ran two extra cycles without soap so I wouldn't have the white bumps and streaks.  I took out the bottom tray and there was a massive puddle under it.  I tried to clean it up with a dish towel and cut my finger on a piece of glass that was stuck into the edge of the filter.  But that couldn't block the whole thing.  Can I take apart the whole bottom and clean it out first?  How do you unscrew those funny looking screws throughout the bottom of the washer?  I need help.  Thanks,  Diana
5 Related Answers
Anonymous
  • Posted on Dec 02, 2007
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Mike
  • 677 Answers
  • Posted on Apr 10, 2008
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Anonymous
  • 39 Answers
  • Posted on Oct 29, 2009
SOURCE: Bosch dishwasher continues to run (Model SHX46A02UC)
searched oother sites. some report a circuit board problem where one of the solder joints overheated and burned out of contact. check yours and repair/replace if that is the problem.
if not at least you can rule it out.
Anonymous
  • 43501 Answers
  • Posted on Oct 27, 2010
SOURCE: the soap is not dispensing
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Anonymous
  • 2605 Answers
  • Posted on Aug 18, 2011
SOURCE: Bosch dishwasher, Model SHX45PO5UC
Hello, welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay, hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last. Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck.
Regards,
Macmarkus :)
Testimonial: " Well thought out response and description. Since washer is still under warranty for control unit we will probably have the Bosch Service Rep. repair"
Bosch Series 6 Tap error symbol lit but pump and drain hose are fine. What can it be?
That normally signifies a leak. Under the machine there is a plastic pan with a sensor in it. However Bosch have a different idea.
https://www.google.com/search?q=Bosch+Series+6+dishwasher+Tap+error+symbol
Palmolive liquid detergent was put in rinse aid recepticle.
I don't understand your question. But, I am going to try to answer based on a "given" I picked. Please read on.
Is the problem you put non dish washing soap into the dishwasher?
... and you want to remove it (soap) without removing ...
the receptacle?
the machine?
If you have non dishwashing soap in a dishwasher, the BIG problem is the suds, followed by the soap is not effective, and it cannot necessarily be removed from the dishes. The suds go from a couple little drops of soap to enough suds to fill Grand Central Station, including your kitchen. Am I close?
What I did when (I did it) this happened is, I put a product called "Anti-Foam" (I just HAPPEN to have a hot-tub) into the dishwasher which killed the suds. I cleaned the mess up off the floor, ran the rinse cycle only, dishwasher empty. Then, I ran the dishwasher again with dishwasher soap to make sure it was clean. THEN, I took the non dishwasher soap out of the cupboard where it sat next to the dishwasher soap and put it elsewhere!
So, what should you do? Go to the pool and hot tub place near you and get a small bottle of "Anti Foam" and do as I did. Expect to pay about $10.00 for the bottle.
Alterntively, you could remove the lower basket, sop as much water out as you can and then run the machine on a rinse cycle to see what happens.
While at the pool place, you might find a hot tub you like. Hey, you already have some of the chemical!
Thanks for your question at FixYa.com
We own a Bosch SHU5307UC dishwasher. Recently, during the 60 minute cycle, the foam builds up and at the end you can see all of it on the bottom. And the last minute dispaly stays on for a while. It...
the unit is over sudzing cut back on soap and dont clean dishes and then put them in dishwasher.dont use to much of the soap with jet dry. regular soap without jet dry in it then add and fill jet dry compartment
2answers
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
3helpful
2answers
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
My bosch dishwasher gets stuck in wash mode. We have to turn the dial to move to the next cycle. When we check inside soap suds are built up on the bottom. We use less than a 1/2 of an Electrasol tablet,...
Have you checked it is draining properly? Partially-blocked drainage would likely be detected and cause the dishwasher to stop mid cycle, with soap suds left behind. I would check (1) the drain filters inside the dishwasher and (2) that the hose is not kinked (3) that all the S-bends etc where the dishwasher hose connects to the drain under the sink are clear.
Jan 30, 2018 • Dishwashers
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
1helpful
3answers
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
