Question about Samsung Refrigerators
My refrigerator overheats - Samsung Refrigerators
    Sergeant:
  • 154 Answers
Change the thermostat
you wil get fixed
Posted on Oct 21, 2008
I recently replaced the engine on my Citroen c4 2005 model, now the warning lights stay on, the engine overheat, abs and anti pollution warning lights stay on.
The problem for engine overheating rise due to insufficient refrigerant. Try recharging the refrigerant tank with fresh refrigerant and water. If the refrigerant in the tank is of poor quality then also engine overheat.
The reason for ABS light to come may be due to air in the brake fluid line. Try brake bleeding to remove the air bubbles. Also the faulty brake actuator line may cause the problem. Check for actuators on each wheel.
Pollution warning light comes on if the exhaust system not works properly. Check for faulty Oxygen sensor or faulty catalytic convertor.
Jul 10, 2013 | Cars & Trucks
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
My refrigerator quit cooling. The lights work, and it routinely makes a clicking sound like it trying to do something. It is a Whirlpool ED22GW approximately 10 years old. Any ideas?
If the clicking is right at the compressor, there is an overheat switch there. If the compressor is not humming normally, it may be the start capacitor, or the compressor itself.
Check for dust buildup on the coils, that will overheat the compressor, same for a fan that is not working.
Mar 15, 2012 | Whirlpool Refrigerators
My refrigerator isn't staying cold nor is the
Look and see if coils need cleaning below. Do a good clean. Feel the compressor, if it's hot to the touch or cold it may have a bad relay. A relay can fail to drop circuits (causing the compressor to overheat) and open (causing the compressor to be idle).themobilian_2327.jpg
May 09, 2011 | Frigidaire Side by Side Refrigerator 23...
My DRB1901C is not freezing. It's sounds like its trying to kick over for a few seconds then fails.
If neither cooler or freezer is working it sounds like the compressor is locked up. When that happens it tries to start and will hold the start capacitor in until it overheats the safety contacts. It will overheat in about 3 seconds and then kick out. This happens sometimes if the door is opened right after the compressor has turned off because it is cold enough in the cooler/freezer. However if this continues time after time and the compressor does not start, you probably need a new compressor. You may consider a new refrigerator, since compressor changeouts are fairly expensive.
Sep 21, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
Compressor motor won't start. Hums and clicks
Most likely the problem is either the condenser coil is very dirty or the condenser fan isn't working causing the compressor motor to overheat and cycle off on its internal thermal limit or the compressor capacitor is defective causing the compressor to overheat and cycle off.
Nov 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
Dec 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Sub zero 632S error code 21
EC 21 has nothing to do with the refigerator. From the 600-2 series service manual page 3-21 EC 21 is Defrost Overheat fault.
The defrost system is only in the freezer and on a completely seperate refrigeration system. Clear the EC by holding the bell key pad down until you here a tone this is going to be a minimum of 15 but can be as long as 30 depending on the generation of your appliance. The part that you will most likely need to replace is the defrost terminator which stops the defrost cycle. You may have also had a problem in the refrigeration section which did fix by yourself, good job.
Oct 22, 2008 | Sub-Zero 632 / S
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
