Question about Samsung PCL6215R 62" Rear Projection Television
3d/rainbow affect in the middle of watcing a movie, our televsion's screen bowed at the top and bottom of the screen. it casted a shadow like rainbow over the entire picture and also made it kind of blury. what can i do to fix?
    President:
  • 3,130 Answers
Sorry to tell ya Gemini, but there are no user serviceable parts inside a TV set unless your a technician as theres several safety issues of Hi Voltage involved as well as unsoldering and soldering. You Have a convergence problem or Pincussion issue with your set. No quick fix for this one. You need to call in a pro to assist you with this repair. Good Luck
Posted on Jul 15, 2006
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
My RCA big screen TV picture now looks like 3D without the glasses. The picture also bows in at the top and bottom in the middle of the screen. What would cause this?
Go to menu then setup if you donot see convergence on menu then you have a blowed Fuse FL231 it will be on Bottom board to left side onthe righht side of FBT flyback transfomer there is 3 of them in a roll small brwn rectangler looking caps But are fuses the one in the middle is it. Call Mats for fuse 1-800-628-1118
Sep 26, 2009 | RCA Televison & Video
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen looks like its in 3d
LOOK FOR OPEN FUSE (CTM) BY IHVT, THE MIDDLE ONE.
Feb 20, 2009 | RCA P52937 52" Rear Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Tv screen is squeezed only straightens out if i bump the top of tv
This is likely your convergence IC solder connections. Does it look bowed and rainbow colored? The red, green, and blue will be mis-aligned causing a shadow effect. If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
Dec 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
3d affect
have the dm board checked
Sep 08, 2008 | Zenith R57W46 57" Rear Projection...
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung PCL6215R 62" Rear Projection Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
