Question about Dayton (3E379) Heater
Does our heater have a reset switch
We have a dayton ceiling mounted heater. It is suppose to be turned on by thermostat. It is not restarting, is there a reset switch????? It has power. Daton model2yu62,,4104-2536-001
  • 1,420 Answers
Turn power off at the emergency switch or breaker. You may want to test the safeties in the unit. Sometimes they pop and are not resettable and have to be replaced
Posted on Oct 21, 2008
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide - manualzz.com
manualzz.com/doc/1285710/dayton-3e134e-troubleshooting-guide
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
plumbingandhvac.ca/images/documents/PHVAC_Sept-Oct03.pdf
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
100 thousand btu dayton cieling mounted gas heater will heat how many cubic ft
100k input is about 80k output, and this will typically be on a 1,200-2,000 sq ft home depending on ceiling height and location ,Montana or Los Amgeles?
Oct 29, 2012 | Dayton Heating & Cooling
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
Looking for bimetalic thermostat switch for the 5000 watt Fahrenheat ceiling mount heater. do you have a parts source?
My place of choice when purchasing for the warehouse is Grainger, if you have one close by. They usually have these items in stock or will get them for you quickly. Give them a try.
Dec 22, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a dayton 30,000 btu heater ,,it will run
If you are pressing a small round switch with a tiny button in the center...means a bad heat exchanger. The heat from the exchangeris going where it is not supposed to and tripping a roll out switch. Have the exchanger checked for cracks or holes.....check vent pipe to make sure not plugged
May 09, 2010 | Dayton (3E386) Heater
I am having a problem with a dayton(3E229D) gas heater. It has a standalone pilot that is lit and stays lit. The problem is that the burners don't ignite. I turn the heat on at the thermostat the fan comes...
if you can use a meter check for 24 volts at the valve when you call for heat. If you have 24 volts and no burners then the valve is bad, if you do not have 24 volts then another safety is locking out the valve
Dec 11, 2009 | Dayton Gas Furnace Heater
Can the G73 be hooked up to an wall thermostat and allow it to over ride the unit thermostat? I want to install this is in a greenhouse and would like to have the thermostat on the wall down lower and not...
Yes, but it will require some knowledge of electric to do that. You will need a line voltage thermostat and mostly like have to have that run a contactor that will be wired to bypass the heater thermostat. A good electrician should be able to to this for you very easily.
Nov 09, 2009 | Dayton G73 Utility Heater
Dayton (3E379) Heater Logo
105 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
