Firewire/usb drive no longer powers on
Hi, my hard drive which came formatted for my mac was originally used with my laptop. I brought it to the office and hooked it up to my desktop (mac) to export a video project through compressor. that was fine. saved without any problems. I closed out through the normal process and then transferred to a second desktop (mac also) to transfer files from it. again, through the normal process, it was fine. When I went back to the second desktop to finish the project, it would not power on. I have changed cables (even though this is brand new) tried on all three computers and nothing seems to work. A friend told me that the portable is only used for one computer and cannot be interchanged. Unfortunately, I was told this AFTER the fact! Is that true? Is there a way to get the files off of the portable? Thanks in advance!
  • akipaki Oct 21, 2008
    Thanks. I talked to someone from the geeksquad and they told me to bring it in and let them check it out. He suggested that I try the usb cable since that usually will give it power but if it still didn't work, to drop it off. When I use the firewire, the light doesn't come on. When I use the USB the light comes on but the computer doesn't recognize the drive. He told me that my files are still on there and it can still be retrieved. Unfortunately, I called 20 minutes before closing...go figure! I just hope he's correct! I've only had this drive for a little over a week. I bought it because I wanted to do some editing while on a plane to CA which is a 5 hour flight. It did a great job and I was very happy with it. What's sad is that this happened moments after the whole job was completed and ready to be set into place in DVD Studio and then burned! Needless to say, I've handled this very well...I'm quite proud of myself...
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    nope..that is not true..however, there is a chance that one of those machines may have infected your ext drive with a nasty...
    to get the files off a portable, use the repair services link on main page at fixya to find a local computer hard drive recovery specialist.
    and for goodness sakes, use an online back up, like mozy.com next time..
  • 95 Answers
If the drive doesn't even attempt to spin up and appears to be completely dead then most likely it's the PCB which is dead. Just to confirm you can remove the drive from external enclosure and connect it directly to computer. If still doesn't power up then most likely the PCB is dead.You could try to get another hard drive of the same model and try to swap PCB. Not sure if it's gonna work though.
Posted on Oct 21, 2008
I have two dead (power supply) PC laptops that I would like to recover some music and pictures from. What is the most economical way to do this now that I have a macbook pro?
When you put the hard drives into an USB hard drive adapter case you cannot boot up the laptops using the external USB hard drive unless the laptop's BIOS has the option to allow the USB device as a boot device.
You can plug the external USB hard drive into any PC/laptop to copy files from the USB hard drive to the PC/laptop.
The MAC cannot read or write to the external USB hard drive unless the hard drive had been formatted in FAT32. There is no way a MAC can read a NTFS formatted hard drive and it will want to format the hard drive.
Oct 05, 2012 | Computers & Internet
My WD External hard drive is no longer recognized by my Mac. It was fine when I went to bed. Showed no warning symptoms that I am aware of.
I would like to know the way the Drive is connected to MAC.
Have you connected it using USB or Firewire ?
If you have connected it using Firewire, Try connecting it using USB 2.0 Cable.
Let me know.
Regards,
Ron
Dec 10, 2010 | Western Digital 4TB My Book Studio II Hard...
When I connect my hard drive - its asking me to format the disk
HI. you are right DO NOT FORMAT!. First try removing the hard drive from the case and connect it to another computer to make sure it's not the hard drive. Also try other computers and other Operating Systems, Linux, Mac. If you have a friend with a mac (everybody knows one) try using the other interfaces - connect it via USB or Firewire, or eSATA on Mac and Windows. I had many issues like this and I was able to recover the data of Windows using Mac and viceversa. I hope this helps and don't forget to rate and give positive feedback for our free support today. Thank you :D
Apr 29, 2010 | Buffalo Technology DriveStation Combo 4 1...
Where can I find a Mac driver from a Simpletech 250gb Marshmallow It has been formatted on a PC. I now want to reformat it and use it on my Powerbook G4 OS 10.4.7
You shouldn't need a special driver, but you do need to plug in the usb y cable to 2 usb ports. Normally 1 usb port doesn't supply enough power to make external USB drives go. That is why I prefer firewire, it supplies much more power at higher sustained rates. Once the drive is going just open the Disk Utility and format for your needs. If you need to share files with a PC, partition as MS-DOS (FAT). If you are sharing with a mac or not using the drive on other computers, format as extended with journaling.
Jun 20, 2009 | SimpleTech Signature Mini 250GB External...
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
Today my firewire bus powered mac mini 320GB external hard drive (that i bought this year) stopped being powered by firewire alone and needed the USB plugging in as well to be recognised and used...the...
Hi-
Chances are these large memory hard drive should be plugin with a USB and adapter of its own since 320Gb is too big and needs power to be able to recognize. But if you find it defective you have a year warranty from the manufacturer, you can call them up for a replacement.
Hope this help. Thanks for using Fixya!
Jul 16, 2008 | Computers & Internet
Bytecc 2.5 Mobile HDD Hotdrive
You don't need any specific software for Windows 2000 or above - the operating system will have the correct drivers built-in.
It should mount either on FireWire or USB (depends on which version you have - there's also a combo version).
If you're connecting via FireWire, you will need to make sure you are using a powered 6-pin FireWire connection. If your computer only has a 4-pin FireWire port, it won't provide power to the drive, so the drive won't spin up, and the system won't see it.
If you're connecting via USB, make sure you're connected to a USB 2.0 port. If you're connecting to USB 1.1, you need to connect both USB connectors on the supplied USB cable to the PC. One connector is data+power, and the other connector (the one that "branches off") is just power.
Check whether the device appears in Device Manager (hit Windows-Pause, or right-click My Computer go to Properties, Hardware, then click Device Manager).
It should appear as a hard disk drive.
Since your friend was using it on a Mac, it might be formatted as a Mac volume so Windows won't mount it as a drive letter.
Right-click My Computer, go to Manage, then click Disk Management. Either a window will pop up and ask you about initializing the disk, or an additional disk with "Unknown parititon" will appear as Removable Disk. Whatever you do, do not mess with any of the disk blocks with drive letters, especially C: as that's your system drive.
The easier method may simply be to ask your friend for format the disk as FAT32 for you. Then it'll mount in Windows and you can format it as NTFS if you need to.
May 09, 2008 | MicroNet Technology Titanium (TFDU16072A)...
Mac My Passport Essential Hard Drive 320GB
This could be a formatting issue, a power issue, or, if you use a hub, it may be a latency issue as well.
Mac's, in general, do not recognize NTFS formatted hard drives. Check the drive properties to see how it is formatted. If this is the case, you can try to reformat the drive as FAT32 (using the MAC) and start over. Keep in mind that you may run into partition size limitations, depending on how current your computers are set up.
Some USB ports limit power to 400-500ma per port, the Passport Essential needs a bit more than 1000ma and won't work at all with these computers. Other USB ports/hubs limit the total power available for all devices combined... this is why, in your case, you can use one drive, but not both.
FYI, higher speed devices also tend to need shorter cables due to latency. (Light & electricity travels about 1 foot, or 30 cm, in a billionth of a second; this limits the size of high speed devices. In layman's terms, latency is the Brontosaurus effect, since the head takes a while to talk to the tail.)
To boost power, Western Digital recommends using a 22" USB 2.0 Power Booster Cable (WDCA029RNN) to combine the power of two USB ports into the one Passport Essential USB port--it is also a bit longer than the original 18 inch cable. For all EXCEPT the black Passport Essential drive, you may also the WD Passport™ Power Supply Adapter (WDPS021 for the US voltage version). See Western Digital knowledge base ID 1296 for more on this issue.
Hope this helps!
Mar 31, 2008 | Computers & Internet
My secondary hardrive was accidentaly reformateed
well depending on what type of format, the content may still be retreivable. What is your computer/OS?
Oct 19, 2007 | Western Digital WDG1C2500N MyBook Premium...
Saying disk not readable
you could try a repartition / reformat, if the drive is detected at all, or you could try running scandisk/disktools, to try and recover / repair the TOC/ FAT
Apr 11, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
