Question about Clarion CALYPSO SIRIUS Radio Receiver
Clarion Calypso display dim
Display dims to unreadable but will brighten if receiver is moved in base. This occurs in all of 5 bases that the receiver is used in.
I have this exact same problem and I have solved it by the following method. Open the unit (2 screws), remove the silver box (3 screws and gold pin connectors), and remove the circuit board (2 screws). You will see the screen is connected to the circuit board by a ribbon cable and two poles with metal connectors that actually go through the circuit board. One of the poles moved freely in and out of the circuit board on my unit, the other was still fixed in place and could not be removed easily. I found that when this pole was fully connected, the backlight functioned and did not when the connection was broken. I soldered the pole in place which solved the problem (maintained the connection).
brad
Posted on Jun 16, 2010
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Brightening dimming tv
Check for any loose solder terminals at its video output section. This board can be located on the CRT base, will directly plugged on to its back.
Jul 26, 2013 | Emerson Televison & Video
The backlight on garmin legend is dim - how do i brighten it
When the unit is on, press the bottom right side button on the GPS unit. A slider will appear to increase brightness, use your toggle to move the slider up.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 20, 2009 | Garmin eTrex Legend GPS Receiver
The display is dim on the oven. Everything works
1. Sometimes you can clean it inside to brighten it up for a while.
2. In some cases, we can replace the VFD to brighten one up if it's available for a given model.
3. The last solution is to replace the control circuit board.
For more specifics on the options 2 & 3, we would need your brand and full model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your symptoms, "dim display".
As for suggestion # 1, cleaning:
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Dec 13, 2009 | Jenn-Air JMC7000 Microwave Oven
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
I have a newer sony receiver that suddenly had the same problem
The display operates on ac and dc voltage. The outer pins on the display should read approx. 3 to 5 volts dc.It might read more. If the circuit traces are good to the transformer the ac will be there. The dc is supplied by a zener diode. The zener diode is shorted or breaking down. This will cause a dim display. Follow the display's outer pins circuit traces to locate the diode and verify the circuit traces are not broken as these lines sometimes are run down the edges of the boards. The edge of a board is a popular place for a board to have a crack and break some traces. Good luck, barneyluc
Sep 25, 2009 | Sony STR-DE345 Receiver
Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
May 04, 2008 | GE JKP45 Electric Double Oven
Front Display Dimming - Almost Totally Gone
Check and see if you don't have a auto dim setting on or you changed Display setting.
I have same Amp and this happened to me also.
Feb 25, 2008 | Harman Kardon AVR 125 Receiver
Display dims on certain menu items
The display will dim for certain features that are not available for use in your current configuration or current operation.
For example; if you do not have an antenna plugged in then the selection for the tuner will be dimmed on the display.
Oct 26, 2007 | Sony STR-DG600 Receiver
Clarion CALYPSO SIRIUS Radio Receiver Logo
233 people viewed this question
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
Anthony Kelly
Anthony Kelly
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
