Question about HP Photosmart 2610 All-In-One InkJet Printer
HP Photosmart 2610 will not initialize
When power is applied, the HP logo appears on the LCD along with the word "invent" and a progress bar. In about 20 seconds, the progress bar freezes, and within a few more seconds the screen becomes blank for a second, then the above cycle is repeated forever. The printer never initializes, never makes a sound, and never is recognized by the computer.
It was working just fine the day before. The printer wasn't moved or jarred, nor were any cartridges changed or paper added.
I have tried unplugging the USB cable, unplugging and reinserting the power cable, and going through the "partial reset", "semi-full reset", and "full reset" procedures I found at another website. Nothing solves the problem, although "full reset" appears briefly on the screen when I try that procedure.
SOURCE: HP 7410 Officejet will not turn on - keeps showing "Invent" logo
The solution located here works!
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Posted on Aug 09, 2009
  • 667 Answers
SOURCE: C4280 photosmart printer - printer screen says
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Posted on Apr 01, 2010
SOURCE: HP Photosmart 2610 displays Error: Oxc0620004
In addition to the error message Ihad a display of flashing lightsI disconnected all the leads anf placed theprinter on a table for easy access. Searched for scraps of paper etc none.THen noticed that the back panel was not properly secured.Tidiedthis up-reconnected OK
SOURCE: My HP Officejet 7410 Unit
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Posted on Sep 14, 2010
  • 1044 Answers
SOURCE: My HP Photosmart C6180 All-in-one turns off
The way you have described your problem gives indication that the problem lies with the electronic circuit/control panel. Therefore I would suggest you to contact your local HP service center/dealer and ask them to replace the machine/part if it is within the warranty period. I will not advise you to open and touch the electronic circuit unless you are a technician.
Posted on Nov 23, 2010
My c6180 when turned on displays a blue screen with the hp logo and a bar at the bottom. the bar shows loadup progress but suddenly a warning about not unpluging it from the wall appears and then it starts...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers . 579e7fb.jpg
Jan 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 8050, printer is turned on and HP invent screen comes up on the printer with a progress bar moving underneath the bar moves 2 or 3 times and then the cycle starts all over again when it restarts the...
I went through several e-mails with HP on this problem coming out with the impression that nobody was actually reading my messages, they were reacting only to "key words." So the printer has been declared junk (by me) and will be replaced at the earliest opportunity but not with HP I am tending toward an Epson or maybe a Canon.
Thanks for your interest.
Dec 12, 2009 | HP Photosmart 8050 InkJet Printer
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 will not boot. It powers up and the HP logo screen flashe
This was solved really well on this blog. It is some problem with the wifi board. If you disconnect it (no so hard and well explained on the blog) you will have network printing over a cable but no wireless.
Oct 23, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 will not boot. It powers up and the HP logo appears on the screen with a progress bar. The display then scrambles and the power light flashes green. No buttons work or do anything.
connect the printer directly to the wall socket for the power supply if it is connected thrugh surge protector.
perform a reset :
unplug the power cable .
press and hold # and 6 key on the printer..
plug in the cable wait for 20 secs then release the buttons..
after this the printer will re-initialize .. this may take few mins..
and chek after that
Oct 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error Code 0xc19ac3ff
This problem seems to have occurred a few times... The only thing i would adise you to do is call HP and see whats the deal. Number is 800-HP-INVENT
Nov 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart 2610
HI,
u can try to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
Mar 03, 2008 | HP Photosmart 2610 All-In-One InkJet...
Rx3715 will not recover from a hard reset
try removing the battery - for a few minutes to begin witj, then a few hours if that doesn't help.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP Photosmart 2610 All-In-One InkJet Printer Logo
156 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
