Question about Refrigerators
My side by side will not defrost,after replacing the timer and thermostat.
    President:
  • 1,462 Answers
Check continuity thro the heater and also there is usually a thermal fuse in series with the heater - check that as well
Posted on Oct 21, 2008
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Ice forming on the back wall of refrigerator compartment It is a side by side...twenty years old
Hello there,
When you are experiencing ice build up in your refrigerator and a part of the refrigerator is not getting cold, either the fridge or freezer compartment. Then it means there is a problem with a part in the unit.
Investigate these three areas if frost and ice are forming in your freezer and your fridge is not cold enough, test Defrost Timer, Defrost Heater and the defrost thermostat when you detect where the problem is from, replace it.
Before you begin to test your defrost thermostat, defrost heater and defrost timer, make sure you disconnect the appliance's power supply.
Here are some tips for you to go through in order to solve the problem.
Defrost timer testing http://www.fixya.com/support/r10523722-test_defrost_timer Defrost timer replacement http://www.fixya.com/support/r10523742-replace_defrost_timer
Defrost thermostat testing http://www.fixya.com/support/r10513592-test_defrost_thermostat Defrost thermostat replacement http://www.fixya.com/support/r10513650-replace_defrost_thermostat
Defrost heater testing: http://www.fixya.com/support/r10523771-test_defrost_heater Defrost heater replacing: http://www.fixya.com/support/r10523754-replace_defrost_heater
All the best Elect_Comp
Sep 21, 2011 | Sub-Zero 695/O Side by Side Refrigerator
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Defroster not working
Jan 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
DEFROST CYCLE IN FREEZER NOT WORKING PROPERLY BUILD UP OF ICE ON THE OUTSIDE/INSIDE OF ICE DESPENSER
1. Check defrost timer. 2. Check defrost thermostat. 3. Check defrost heater. One of this are more than one may be defective replace.
First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it. Thanks and hope helpful
Jan 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature is set to high. no ice is being made and temp.is not cold on either side .could it be ice on the coil if so how can i fix it?
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Kenmore 5520 / 655202 / 55204 / 55209 Side...
Frost free fridge freezing up
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge frig does not freeze on freezer side
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
