Question about IBM ThinkPad A21m 2628 Notebook
I dont have a lead to any power. can i get one somewhere?
I got this laptop at a local fete for $5 and it was just the laptop. no cords for power or anything, so i was wondering if anyone knows where i could find one.
  • katnmouse Oct 21, 2008
    wasn't there so i sent them an email. but i also have an old Acer something-it doesnt say!!!!GRRRR...but if u r bored (i laugh) tell me and i will tell u everything on the back if u feel like helping. but it says 'missing operating system'
  • Anonymous Nov 05, 2008
    where is the reset button?
    Master:
  • 538 Answers
Sure..laptopparts.com
Posted on Oct 21, 2008
  • A Womans Computer Man
    A Womans Computer Man Oct 21, 2008
    thanks..neat name you have here..
    well..send me an email with that information..pn4pm@yahoo.com
Asus K52jc-sx022v
One possibility is that the plugs where the battery is attached are scr...d up. Try to check them and see if there is any obvious problem... If not, there might be a short-circuit somewhere near the battery (in the laptop, not in the battery..)
Jan 26, 2014 | Computers & Internet
Mirai TV power lead dtl-522p201
hello!
your TV has external power supply, not a "built in". It's not just a "cord", but whole switch mode 100-240volt power supply. Those could be single or multistage DC output. You have to check those parameters off the TV's power input or off sticker at adapter itself. By having this knowledge, you might be able to find similar one locally or try to repair the original one, if you have it, at any local TV or even computer repair shops. Laptops have similar adapters.
Good luck,
Alex.
Feb 19, 2012 | Televison & Video
I need a replacement power cord for my 50" Philips
It will have a standard figure 8 power lead connector at rear.
You should try local electronics store for spare lead.
Feb 05, 2011 | Philips 50PFP5332D 50 in. Plasma...
My laptop will not switch on, i have ordered a new power lead and it worked for a month, there are no lights coming on it just seems dead it was purchased july 2009 for christmas 2009 and first stopped...
Its a common issue for DELL systems. I recommend you request a MOTHERBOARD/AC /POWER CORD replacement .They can send a technician for you or send it to a depot repair.
Jan 20, 2011 | Dell Inspiron 1545 Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Battery dead in my HP laptop will not start with power cord
take out the battery and try to start the computer with it plugged in using the power lead. If this owkrs without the battery being in then the power lead is fine. If this doesnt work it could possibly be the power lead or the power supply inside the laptop. Does the power lead converter (the black box half way down the lead) get warm when plugged in for a while, if so the power supply is probably the fault
Jan 20, 2010 | Computers & Internet
DC power inside computer will not charge battery.
About 99% of the time the DC female adapter is soldered to the motherboard making it near impossible to fix. Getting solder on anything would ruin the motherboard.
It is possible that it is your Power Cord and not the jack on the motherboard. Same problem I had a few weeks go with a clients laptop. You may want to buy a new Power Cord, and try that before you go out and have to get a new motherboard (which can be VERY costly, or even buying a new laptop).
Post the model number of your laptop and I can direct you somewhere to get a good deal on a new power cord.
Mar 16, 2009 | Gateway Computers & Internet
No picture no power red button flashes 4-5 times and shuts off
Try unplugging the 3 convergence yoke plugs and then trying to power on the set. The convergence plugs are located on the board on the left side of the tv looking in from the back and they are 3 identical plugs right next to each other they have a R B and G next to the plugs one letter for each plug just remember which plug goes to which location when you plug them back in.
Jul 16, 2008 | Philips 55P8341 55" Rear Projection...
Maytag Neptune Dryer Raising the top
check your power first breakers trurn them off then on check outlet for 220 then 110 at each side that would be meter leads two flat holes 220 then meter flat hole on one side red wire black lead to round hole should be 110 red lead other side flat hole black lead round hole should be 110 if thats good then pull terminal block cover off check cord for loose or burnt condition if its burnt dont freak just replace terminal block and cord they burn if they werent tight when installed now to get the top up get a putty knife face the drier and about 2 to 3 inches there are two spring clips push in with the putty knife while rasing the edge one at a time if its not the power look for the thermal limiter a small metel disc close to the heating element some are plastic if its open theres your promblem pull one wire off of it or youll get a flase reading through the timer
Dec 26, 2007 | Maytag Neptune MDE5500AY Electric Dryer
IBM ThinkPad A21m 2628 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
