Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Receiving sensor will not light up for garage door opener
  • MsGor1 Nov 14, 2008
    I have the same problem and even changed light bulbs, aligned sensors which are amber and green but sensor light still does not come on.
  • 504 Answers
ASSUMING THEY ARE AIMED CORRECTELY--
YOU MAY HAVE A BROKEN WIRE TO THE SAFETY EYE OR A BAD SAFETY EYE.
TRY RUNNING A TEMPORARY WIRE DIRECT TO BYPASS THE ORIGINAL IF THIS SOLVES THE PROBLEM REPLACE THE WIRE. IF NOT ODDS ARE YOU HAVE A BAD EYE.
HOPE THIS HELPS .
Posted on Jun 11, 2010
  • 74 Answers
Try to align it with the emisor sensor...check wires
Posted on Mar 10, 2009
Liftmaster 1345, sending light is on, receiving light is not on, door will not close, light blinks 10 times, why??
Because we live in a free country the government says garage door openers manufactured after 1993 have to have an inferred safety reversal system (UL325).
You need to adjust the receiving sensor until you have a steady green light, then the garage door opener will function properly again.
Feb 11, 2015 | Building Materials
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I uninstall my garage door sensors. They continue to give me problems, it acts like there is something in front of the sensor and prevents the door from closing.
When you say sensors, are you talking about the photo-eye that checks if obstruction is in path of garage door?
1) You can buy sensors for $20-30. They seem generic
2) The new openers may be set up so by-pass is not an option.
Solution: In that case, you can move sensors above the garage door and put them face to face to see if that helps.
3) The way the sensors work is this. One side produces beam of light. Other side receives light. The receiver keeps a circuit closed at all times when light is received. If no light, then the circuit opens up and an electronic part interprets the lack of signal and turns off opener.
Solution: one side produces light. It does not have a switch. The other side has the switch. You can disconnect (or cut) a wire see which side has the light. The other side has the switch ... cut the 2 wires on the side with a switch, cap them off, and then see if opener works. Next twist the 2 wires together and see if opener works.
4) Fall-back position: Mark your wires and you can put it back the way it was.
Oct 06, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door won't close with remote and I have to hold the pad to make it go down, however it opens just fine.
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving "eyes". These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye "sees" the beam from the sending eye, a green indicator light will glow on the top of the eye. Tweak them a bit. If both lights do not come on you have bad sensors.
Sep 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens but have to hold button in to close
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the eye.
Jan 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
Check the electric eyes. If they don't see each other the door thinks there's something in the way. Blinking light is a safety alert to check the travel path.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sensor lights not working on door opener
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
Dec 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programing limits on a Grifco MK3 Garage door Operator
It has the "Protector System" (safety sensors). chec the sensor indicator light on the receivinng eye the green light had a slight flicker.cleaned both the sending eye and receiving eye lens of dust and cob webs, then realigned the receiving sensor for a steady green indicator light. then check the door function it now works fine.over time, temperature, and viberation the sensors become dirty and get out of alignment, as no one had tampered with the sensor alignment prior to this. Hope this works for you.
Nov 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
255 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
