Back to:
Tags:
Sony STR-DE945 5.1 Channels Receiver
Mono only mode problem (by 4 users)
posted by Scorpio71 on Jul 14, 2006
Hi all,
This problem has started to get progressivly worse over time. When I first turn it on, it clicks and I have normal sound (Front L/R and Center). It may or may not click again immediately and only play from the left speaker. It used to only do this every once in awhile, no it almost always immediately goes into "left speaker only" mode after that first click you hear when you turn it on...
This morning, it clicked and no sound came out of the left speaker...sounds like the thing is going bad....
Any ideas?
I tried disconnecting speakers and plugging things in one at a time, but the behavior is the same.
Thanks
Mike
Comment by Scorpio71, posted on Jul 14, 2006
Well, I started to move the received around and when I pressed / tapped on the top of the case (back right), all the channels came on. I guess there is something loose in there.
Thanks
Mike
Comment by Scorpio71, posted on Jul 16, 2006
Thanks bmw,
That makes perfect sense. I will try this in the next day or so.
Mike
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by mamalenf, posted on Mar 13, 2008
I have the Sony STR-DE945 with the same problem. It appears that the clicking sound is from one or more of the relays that are used to mute the sound to the speakers until the amp is fully powered up. I've been searching the web for similar problems and how to correct it. I've also seen where tapping on the top of the case causes the relay to click. Something is loose and my next step, after purchasing the service manual is to go inside and check solder connections. I'm not sure I want to try replacing components at this time.
Comment by dcpunk582, posted on Feb 29, 2008
i have a pioneer vsx-d914 and my problem is acts like its muted no sound from speaker outs, there is a very lil sound when its turned pretty much all the way up. there is no obveious damaged nothing broken or burnt. does NOT go into protect mode. turns on powers up fine everything else seems to work(all its modes) all the fuses inside of it are good as well. if it maters i do not have the remote. any help would be great .
thanx Jon
Comment by lococ, posted on Dec 01, 2007
My problem is very similar. I have a Technics SU-G91. I can get sound from the right channel for A-B. The Left channel works but the sound is very poor. It is not very loud and sounds distorted. I have soldered all the points on the relay an it's the same. I was only able to find one realy. Is there anything else it could be? Thank you.
Best Solution
FixYa! (100)
toni5
Rank:Apprentice Apprentice
Rating: 91%, 8 votes
It sounds as if you have dirty or sicky relays in the speaker outputs. These relays are there so protect the amplifier's circuitry should there be a problem with your speaker system. If the amp detects a fault it won't switch the relay to allow the speaker to be used.
Obviously you don't have a speaker problem but because the relays are dirty or sticking audio isn't being allowed through. By tapping the unit it's activating the relays as it should.
If you wish to find the culprits, WITH THE POWER PLUG PULLED OUT.
look for small clear plastic boxes on the motherboard, Maybe 1 1/2 inches tall and and inch square. With a bit of pulling and luck the clear plastic top should pop off and leave the innards on display. Gently insert a very fine file between the contact points and give them a few rubs. Do this to all the contacts and put the plastic top back on. Try the unit out and see if one channel works. If it's all OK do the rest in the same way.
It's these relays which you hear clicking by the way. If they're dirty they'll still click but not do their job.
bmw
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Mono only mode problem:
I don't want to Accept this solution
Solution #2
posted on Jul 17, 2006
Helpful (85)
Pravin
Rank:Wiz Wiz
Rating: 83%, 567 votes
Toni5 gave the correct reasons for the problem you are facing.
But, instead of usinga file to clkean the relay's contacts, i normally use a fine grain emery sheet or Sand paper. Cut up a small patch maybe an inch square, and use these.
Thank You!
Solution #3
posted on Jan 13, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Oh, well in my case Tony5 is wrong, relays are blue and cover not coming up, as suggested JDSpin I took out the circuit board which is actually not that easy as he says (be patiend!!!) and just re-solder all of relays joints. If they are look just fine, You might want to take a magnifying lens to take a closer look on the joints.
Good Luck
Thanks JDSpin
Thank You!
Solution #4
posted on Nov 04, 2006
Not Rated (0)
JDSpin
Rating: 0%, 0 votes
Mike I have the same receiver and until recently had the exact same problem. It would click on start up and as it warmed up it got progressively worse, sound from the speakers was sometimes terrible and very muffled. However, if you tapped the top it would click again and them work again for a while. Anyway, I finally got around to taking the thing apart and found the problem was caused by dry solder joints to the relays attached to the main circuit board.
To fix it, take the cover off and you will see 4 blue relays in a row OSA-SS-212DM3. You will then have to take out the circuit board which is actually easier than it looks. Once you have it out just re-solder the dry joints. Alternatively take it to a TV repair shop and they should be able to do it for you relatively inexpensively. I hope this helps.
Thank You!
Solution #5
posted on Sep 03, 2006
Not Rated (0)
kevinm
Rating: 100%, 1 votes
I had a similar problem, but all speakers would go off (not just one channel). I would hear a click and functionality would be temporarily restored when I over-twisted the A/B Switch, tapped the shelf and/or pressed on different parts of the case.
After several experiments, I found the solder joints were broken for the two sets of header pins for the board-to-board connectors on the Display PCB. These connectors link to the Muting and Power PCBs located on the left and right sides respectively. Because the through holes are not plated and there is mechanical interaction (board-to-board flex connection and in the case of the interface with the Power PCB--constant button twisting and pressing), these solder connections are especially prone to failure.
To confirm this problem, you will need to remove the front panel assembly (after you have removed the cover, remove eight screws around front plastic, unplug two flex cables and remove one end of ground strap). The back of the 5 pin header connecting the Display PCB to the Power PCB can be found on the upper right side of the Display board (marked with a "5" in a square); you may be able to see fractures in the solder connections or feel the pins wiggle; otherwise, you can easily confirm this problem with a continuity meter; make sure that you are testing the continuity/connection between the pin and the board itself while moving the pins/connection. The pins for the Muting PCB connector are on the far left side of the Display board (by "DISPLAY" marking).
Resoldering the header pens should restore happiness for a few more years of successful performance.
Thank You!
Can you Help with these Receivers problems?
my receiver keeps blowing the same 3 fuses. I replaced all...
I get very low, distorted sound from right front speaker,...
Hi, Whenever I use my audio reciever through the stereo...
I'm also having the issue of the stereo clicking and the...
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
