Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Can connect via the enthernet cable but wont go wireless..
Wont recognise the D-link when I try wireless..
  • vickykhan Nov 03, 2008
    i have a same router but the problem is i m not getting ip when i connected my router to modem it gives me the ip like192.168.1.100 and gaitway is 192.168.1.1 which is not normally my ISP ip's when i use LAN port using Rj 45 cable it has a same problem both in wireless and direct cable connection) my wireless router continuously have blinker light which normally do'nt have.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm..what kind of computer are you using`?
    Genius:
  • 1,124 Answers
1) Check your wireless network card to make sure its configured correctly and working properly.
2) If you're trying to get access thru a laptop be sure that your wireless network card is ON
3) Check if your wireless network is available to connect.
Posted on Oct 28, 2008
Can i connect the router to pc,not the other way @,???
Nope. The router has and uses translations like ARP (Address Resolution Protocol) and other protocols that are a required part of most Ethernet networks via OSI layers. Plus it must assign IP's. Your network card just can't preform those task like sending data packets to and from to find their destination and keep them from being jumbled data.
You may be able use it as hub, but you won't get wireless.
May 26, 2013 | Computers & Internet
My D-link router (dir 615) saying is connected but have no internet access
Wired or wireless? Check all cables, have you tried to connect with a Ethernet cable to the ISP modem, if it connects, try connecting via the cable to the D-link. Work you way through the devices one by one.If it connects via the cable, it's the computer's wireless adapter. Will other computers connect? Or contact your ISP to verify the signal, have a tech come out to analyze the signal. It may be outside. It's happened before, to me.
Dec 26, 2012 | D-Link DIR-615 Wireless Router
Wont connect to wireless
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
Apr 29, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
No controler will connect to my playstation 3 ?
Did you try to connect first using the USB cable? I have had this problem because I take my controller to my friends house sometimes to use on his console for 2 player games. I always have to connect via cable first to get the controller recognised, after that I can use it wirelessly. Then when I take it home again, same problem. But connecting via cable first always fixes it.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Linskys wireless-g broadband router not connecting to network
first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
Jun 07, 2009 | Linksys Wireless-G Broadband Router
D link dsl 2640r cant find my wireless setting on my laptop
do you have the drivers, or a wireless nic in your laptop?
Feb 12, 2009 | Sony Computers & Internet
Netgear WPN824 wireless router
there is no reason why you shouldnt connect at 108 mpbs, so there are only a coulple of things you can try, the first is to change the channel that your router transmits on within the router settings, although this should automatically be done by the router when it comes up against any interference. Secondly try the adapter in a different usb port as USB 2.0 should be used and the port may not be recognised as a high speed port. Double check the router connection transmition speeds is set at 108 mbps; as it would also be able to transmit at a lower speed of 54 mbps so as to be backward compatable with 54 mbps adapters
Jun 30, 2007 | NetGear RangeMax WPN824 Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
