Question about HP LaserJet 2420 Printer
My HP printer 2420 leaves "ghost" prints on the pages.
What do I need to do to get the printer to print clean copies of my work without leaving these "ghost" prints on the pages?  And how do I do it.  I've misplaced my manual.
Thanks
  • 64 Answers
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Posted on Nov 25, 2008
I agree with "cops", swap out the fuser.
Posted on Apr 01, 2009
    Scholar:
  • 91 Answers
A possible solution from HP's Service Guide for the LaserJet 2400 Series Printer:
Random image repetition:
If an image that appears at the top of the page (in solid black) repeats farther down the page (in a gray field), the toner might not have been completely erased from the last job. (The repeated image might be lighter or darker than the field it appears in.)
● Change the tone (darkness) of the field that the repeated image appears in.
● Change the order in which the images are printed. For example, have the lighter image at the top of the page, and the darker image farther down the page.
● From the software application, rotate the whole page 180° to print the lighter image first.
● If the defect occurs later in a print job, turn the printer off for 10 minutes, and then turn the printer on to restart the print job.
Last, but not least, replace thr print cartridge. Let me know if this works. Binary Bob
Posted on Nov 28, 2008
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
It leaves image ghosts all over the page when printing
You need to buy the higher quality paper required for color laser printers. Plain old copy paper doesn't work
Oct 19, 2009 | HP Color LaserJet 2600n Printer
It will not print or copy without toner lines on
Check the drum ,blade or the fuser rollers and clean or replace.
Jun 26, 2009 | Office Equipment & Supplies
The document prints but leaves ghost images on the page also
A laserjet is different than a inkjet.
Ghosting is either the toner or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 25, 2009 | HP LaserJet 1020 Printer
HP LaserJet 2420d printing by itself
I found out that another person was networked with my computer so I disconnected them and the printer is now in great working order.
Sep 30, 2008 | HP LaserJet 2420 Printer
HP Laserjet 1150 Ghost copy
clean the heads, re calibrate...do a test page, try again.
Feb 26, 2008 | HP LaserJet 1150 Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
2,212 people viewed this question
Ben Johnson
